Steering pump ?
Old Today | 02:51 PM
redwingvette's Avatar
redwingvette
Default Steering pump ?
How far away from the front crossmember is the pulley/ belt on my 73 suppose to be? I just replaced my pump but while I was doing the work I was surprised how close it is. I had to remove the brackets just to remove/install the belt. I am wondering if my motor mounts maybe have moved to create this issue. It’s been thirty plus years since I replaced the pump and don’t remember it being that close
Old Today | 05:10 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Is the groove in your PS pump pulley in line with your crank pulley? As in, is the PS pulley all the way on the shaft?
Do you have A/C too? If so, there's an aux. small crank pulley that bolts to the front of the 2-groove pulley that must provide greater clearance.
Here are the two ways the '73 AIM shows the belt arrangement for L48 and L82 engines (It says L48, but the single illustration of an w/AC L82 is identical.)
Old Today | 05:36 PM
SEVNT6's Avatar
SEVNT6
I just looked at mine & it's also close. The front edge of the pulley is less than a 1/2" from the crossmember.
And except for the belt it's all original..
Old Today | 07:29 PM
redwingvette
Looks like my motor mounts are shot.
put a jack under the oil pan to take the wt off and sure enough the motor raised put about a 1/4” which made clearance at the front of the motor quite a bit.
we will see when the new mounts come in of Friday
[img alt="The old mounts
"]https://cimg9.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/img_2726_59d9f3fe43b12fb75dac9aa62f2155b d8b7db054.jpeg[/img]
The old mounts
To Steering pump ?
