C3 times
Old Mar 8, 2003 | 07:17 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: C3 times (SuperFast80)
So does anyone have any idea what the times are with the steel belted (new tires) instead of the bia's plys?
Like I said before, around 14 flat.
:iagree:
Old Mar 8, 2003 | 07:45 PM
70 LS1's Avatar
70 LS1
Default Re: C3 times (Corzvette69)
14 flat
:iagree:
One thing you have to remember is that the 350 Hp of the L46 was gross Hp. The engines today are rated in net Hp. You would be surprised how much that makes a difference. 350 gross equates to somewhere in the low to mid 200's net. Both my L46 and LS1 are rated at 350 Hp, but the LS1 is much, much more powerful.
Old Mar 9, 2003 | 03:30 AM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: C3 times (70 LS1)
It is very easy to change a L46 into an LT1. Carb, intake, and cam. With free flowing exhaust, the 350 can really scream! 2" pipes, mediocre rams horn, and stock QJet/low rise manifold really cut into the potential. Yet my completely factory original L46 w/ QJet ran much better with the simple change to glass packs once all the insulation blew out of them. I was running 2" pipes will hollow bullit shells for several years.
Chuck
Old Mar 9, 2003 | 05:22 AM
timbo79's Avatar
timbo79
Default Re: C3 times (Chuck Harmon)
The reply above is correct: Modify, and renew.. It just takes time AND money
