Whose dome light still works?
Old Feb 26, 2003 | 12:07 AM
Stoge's Avatar
Stoge
Default Re: Whose dome light still works? (corvettemaster)
Like a charm. Even the delay still works.
Old Feb 26, 2003 | 12:09 AM
Stoge's Avatar
Stoge
Default Re: Whose dome light still works? (guppie)
Am I supposed to have a light in the storage area?
No.
[Modified by Simon Alexander, 11:09 PM 2/25/2003]
Old Feb 26, 2003 | 03:22 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Whose dome light still works? (Avette4me)
Work like new - even delay like they're supposed to.
Same here :thumbs:
Old Feb 26, 2003 | 06:32 AM
Yeller81's Avatar
Yeller81
Default Re: Whose dome light still works? (Desertdawg)
Mine works and even the light for the Spare tire lights up .
Yea Haw
:steering:
Old Feb 26, 2003 | 06:37 AM
Jvette73's Avatar
Jvette73
No dome light here. One in the rear compartment and two under the dash near each kick panel and yes they work when the doors are opened or when the headlight **** is twisted to the far left.
Old Feb 26, 2003 | 07:07 AM
groovyjay's Avatar
groovyjay
Default Re: Whose dome light still works? (Mikeb690)
Works every time....usually :D
:iagree:
Old Feb 26, 2003 | 07:36 AM
parklawn's Avatar
parklawn
Default Re: Whose dome light still works? (Yeller81)
Yea Haw
:steering:
Mine too............. :iagree:
Old Feb 26, 2003 | 07:53 AM
Fasteighty's Avatar
Fasteighty
Work like new - even delay like they're supposed to. :party:
:iagree:
Old Feb 26, 2003 | 08:08 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
My courtesy lights work... now. :cheers:
Thems was broke when I got the car. In fact, all the interior lights (dash, etc) didn't work when I got the car. Now that I think about it, everything in the car barely worked if it worked at all.
All that has changed. $26K later, everything works like new... because it is all new. :lol:
Old Feb 26, 2003 | 08:09 AM
amcom6's Avatar
amcom6
St. Jude Donor '05
Default Re: Whose dome light still works? (silvervetteman)
I don't have a dome light, just courtesy any rear compartment , And yes they work.
:iagree: Mine work also :party:
Old Feb 26, 2003 | 09:02 AM
Ganey's Avatar
Ganey
All work. Added another switch to turn off.
:cool:
Old Feb 26, 2003 | 10:43 AM
Edzred72's Avatar
Edzred72
My 77's dome/under dash lights works great. But when it's cold out, the timer doesn't want to shut it off for at least 15 minutes. My 72...After replacing both courtesy light switches in the door, and replacing one of the bulb sockets under the dash...they work great!!! (whew) That was a PITA..
Eddie
Old Feb 26, 2003 | 11:05 AM
  #33
WhyFly's Avatar
WhyFly
They all work, but only come in handy when it's dark. :jester :jester
Old Feb 26, 2003 | 11:22 AM
  #34
Robert N's Avatar
Robert N
Default Re: Whose dome light still works? (WhyFly)
Just like they should. :thumbs:
Old Feb 26, 2003 | 12:26 PM
  #35
desi's Avatar
desi
Default Re: Whose dome light still works? (Alwyn678)
I don't have a dome light, just courtesy any rear compartment , And yes they work. :iagree: mine work also...I also have A light on my Rear view mirror which way cool :cheers:
[Modified by Alwyn678, 4:24 PM 2/25/2003]
:iagree:
One more for YES.
Old Feb 26, 2003 | 12:29 PM
  #36
Sleestak's Avatar
Sleestak
Default Re: Whose dome light still works? (desi)
I have on in the rear compartment and passanger side footwell that come on when the door is open. If there's one in the driver's side footwell it doesn't work.
Old Feb 26, 2003 | 03:08 PM
  #37
Rockn-Roll's Avatar
Rockn-Roll
Default Re: Whose dome light still works? (Vfastboy 73)
All lights work, even have the cool maplight, but is difficult to tell if it's on or off due to the low intensity. There's also a lamp in the center storage compartment with a switch that turns it on if the center storage compartment is opened...interestingly it also sticks out into the jack stand compartment, so opening the center compartment provides light to see into the compartment where the jack stand is...nice for those late night flats.
To Whose dome light still works?
Old Feb 26, 2003 | 03:18 PM
  #38
TedH's Avatar
TedH
Not only do my interior lights work very well, but I also get an audible 'beep beep, beep beep, beep beep...' from my stereo speakers when I initially close the doors. I suspect it is tied to either the aftermarket or the OEM security systems or the interior lighting system. Not sure...
Old Feb 26, 2003 | 06:11 PM
  #39
Mike Rohr's Avatar
Mike Rohr
Been there , done that, had to replace the light switch on my 72, the interior light wouldnt go on when turning the light switch all the way left.
Old Feb 27, 2003 | 10:03 AM
  #40
fauxrs's Avatar
fauxrs
Me too never had a problem, delay works - headlight on alarm works even the courtesy light over the spare tire carrier works - and delays.
No problems.
