Vacuum booster - yahooooooo
Old Mar 10, 2003 | 04:33 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Vacuum booster - yahooooooo
Just starting to look like spring, supposed to be 50 this weekend. Start her up Saturday and, after much digging in hopes that it was something else, the booser took it's final dump! The parts store in town can have a rebuild tomorrow. Tonight I'll start taking it apart. I'm gonna try to reach the 4 bolts from hell by taking out the speedo and tack assembly rather that take the whole dash out. Anyone with an '80 ever try? If so, let me know. Otherwise I'll report tomorrow. Can I say DAMN here? :reddevil
Old Mar 10, 2003 | 04:42 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Vacuum booster - yahooooooo (Avette4me)
yeah, you can say damn but the filter cuts you off at poopie, kiss and butt. go figure. :jester
50? brrr. it was 76 yesterday in vegas. sounds great now but i'm going to regreat all the smack i've been talking this winter when we get to 110*+ during the summer. :nonod:
never had to do the booster on my '81 which should be nearly identical but i would seriously check to see if you have brake fluid in there when you get the master cylinder out. the rear seal of the master cylinder leaks right into that booster and just eats up the diaphragm on the booster. :smash:
Old Mar 10, 2003 | 04:43 PM
BEZ71's Avatar
BEZ71
i just did mine on a '71 auto the only thing i had to remove was the seat and some duct work wasn't that hard at all as long as you have the right tools.
Old Mar 10, 2003 | 04:49 PM
Avette4me's Avatar
Avette4me
Default Re: Vacuum booster - yahooooooo (clutchdust)
Thanks to you both - I really appreciate the tip Clutchdust, I certainly don't want to do it twice.
Old Mar 10, 2003 | 05:28 PM
1979toy's Avatar
1979toy
I am just finishing mine up on my '79. The nuts can be removed and installed by going under the dash with a socket, universal joint and a long extension. Putting them back on requires some amount of dextarity but my old hands were able to get the job done. Be sure that you check the clevis for the correct length.
Old Mar 10, 2003 | 05:46 PM
Avette4me's Avatar
Avette4me
Default Re: Vacuum booster - yahooooooo (1979toy)
Thanks Steve, I'll give it a shot. I got a little spooked just lookin' under there yesterday - Did I say Damn?
Old Mar 10, 2003 | 05:48 PM
Monkeywrench's Avatar
Monkeywrench
Of course it's a whole lot easier when you have everything out of your way
:lol:
http://www.sdotson.com/photos/vettepics/interiorout.jpg
Old Mar 10, 2003 | 06:05 PM
NHvette's Avatar
NHvette
Default Re: Vacuum booster - yahooooooo (Monkeywrench)
:lol:
It's even easier when the firewall is removed from the car. :lolg: :lolg: :lolg:
I took mine off after removing the firewall. The booster was off before my air
compressor could pump all the way up. I don't know why everyone thinks
that it's so difficult. :D :D :jester :jester :D :D
Seriously - if you can get the tach/speedo dash panel out of the way - then you should have a straight shot. Also, replace all the bulbs back there - while it's out.
Good luck.
Old Mar 10, 2003 | 06:56 PM
bigvette1's Avatar
bigvette1
On my 73 the best tool for the job was my 12 year old grandson that is 1/2 the size of me and has much thinner hands. Works great once you show him what you need. Try it or borrow the neighbor.
Old Mar 11, 2003 | 03:59 AM
zwede's Avatar
zwede
Not trying to spook you, but I tried 4 rebuilt boosters and none of them worked right. Yeah, that means I removed the booster many, many times. I finally bought a brand new GM booster and it works perfectly.
First time I replaced the booster it took me 3 hours to get the thing out. The last time I clocked myself at 13 minutes! I didn't remove anything in the interior except the plastic piece behind the pedals (covered a nut).
Old Mar 11, 2003 | 08:45 AM
Avette4me's Avatar
Avette4me
Default Update
Got it out in about 1 - 3/4 hours. I took the speedo and tack assembly out, but the only value in that was to see a little better. There's a trough that the wipers lay in that dips down so you can't really reach them from the speedo area anyway. I'm fairly scrawny and I gotta say that it was tough reaching everything, but it can be done. Hope the parts guy has the replacement as promised so I can get ready for the weekend and put this behind me. Hope I'm luckier than zwede and get a good one. I'm not really interested in being able to do it in 13 minutes :D .
Footnote: Of the 1 - 3/4 hours, about 30 minutes was beer time to congratulate myself for not getting trapped in that mess :D :D
Old Mar 11, 2003 | 08:56 AM
LRPMAN's Avatar
LRPMAN
Default Re: Update (Avette4me)
Hi Folks, Have you added the wonderful tolls called GEARWRENCH not the seras junk bit the REAL gerawrench. WORK LIKE a charm in all those bast places that my FAT OLD HANDS can not get to. :cheers:
To Vacuum booster - yahooooooo
