BRAKE CALIPER PAINT
Old Mar 14, 2003 | 07:28 PM
Oldguard 7's Avatar
Oldguard 7
Default BRAKE CALIPER PAINT
Has anyone painted their brake calipers? If so what is the most popular color?
Old Mar 14, 2003 | 07:52 PM
Zack Wenning's Avatar
Zack Wenning
Default Re: BRAKE CALIPER PAINT (Oldguard 7)
I used something in a spray can called Plasticoat(i think thats what its called) in bright red so itll look the ZO6's bright red calipers. I got it at Walmart and I think they also had black, silver and yellow.
I think the most popular color to paint them is either bright red or grey. The people who paint them grey want them to look stock(as cast), but not rust. The people who paint them red want them to be noticed. :cool:
[Modified by Zack Wenning, 7:52 PM 3/14/2003]
Old Mar 14, 2003 | 08:24 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: BRAKE CALIPER PAINT (Zack Wenning)
I bought the red caliper epoxy from MidA. That stuff hardens really nicely, but I'm sure you can get something locally less expensive. I know there is some spray paint out with Ceramic in it that is pretty tough stuff.
You can tell the Z06's on the GM assembly line because they are the ones coming thru with the RED calipers ;) .
[Modified by SmokedTires, 8:27 PM 3/14/2003]
Old Mar 14, 2003 | 08:30 PM
SharkAttack's Avatar
SharkAttack
Never tried it (calipers don't show behind stock rallye wheels). :nonod:
Old Mar 14, 2003 | 08:34 PM
wayne_69_427's Avatar
wayne_69_427
Just got a kit from Eastwood yesterday 8 colors to chose from. I got black the kit comes with cleaner, paint, hardner, paint brush, even a mixing stick for $47.99. Now thats on my to do list. :thumbs:
Old Mar 14, 2003 | 10:20 PM
Oldguard 7's Avatar
Oldguard 7
My vert is metallic green, what color does anyone think it should be? I was leaning toward black.
Old Mar 15, 2003 | 05:27 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I painted mine using Red Devil polyurethane red, but I don't think I'm crying out for attention. :D It adds some color to an otherwise dark & dingy area. :thumbs:
Old Mar 15, 2003 | 07:56 AM
FeedVaal's Avatar
FeedVaal
Default Re: BRAKE CALIPER PAINT (1970 Stingray)
I went with bright yellow. VHT in a spray can for 5 bucks.
Old Mar 15, 2003 | 09:26 AM
R1234's Avatar
R1234
Black
Old Mar 15, 2003 | 04:47 PM
Oldguard 7's Avatar
Oldguard 7
Default Re: BRAKE CALIPER PAINT (Ed T)
:thumbs: Frame looks immaculate :cool: did you use POR 15? If so how long ago and how often do you keep the 'visible areas' of the frame clean?
Old Mar 15, 2003 | 06:12 PM
gdh's Avatar
gdh
... or you could be like SuperFast80 and paint them hot flaming pink. I painted mine silver last year with a manifold high heat paint, when I put the Cragars' on I will repaint red.
Old Mar 16, 2003 | 03:58 PM
Double Aught's Avatar
Double Aught
I agree, black would be good for you. I have considered doing to my Pace, only because I have a five spoke 17inch wheel and you can see the rusty colored rear calipers and the silverish front calipers. Not to mention, the wheel hubs need to be painted too.
Old Mar 16, 2003 | 06:29 PM
MN-Brent's Avatar
MN-Brent
Default Re: BRAKE CALIPER PAINT (sd pacecar)
Just did my rears today with Red Plastikote caliper paint (900 degree) in the spray can. They turned out beautiful. Bought it at Walmart.
I am replacing the OEM pistons with VBP O-ringers and I had removed the OEMs and springs and wire wheeled them and final cleaned up pretty good with brake cleaner on paper towels. I loosly put in the OEM pistons without the springs back in to allow painting without getting paint into the bores. Also covered up the bleeders and the tapped holes, etc...
Once I put the VBP pistons in, it'll look great. Also setting them up with SS braided brake hoses.
The difference the red made to the housings are remarkable. Im a happy camper!!
Brent...
Old Mar 16, 2003 | 07:54 PM
J75's Avatar
J75
I used the POR15 "bare metal".Looks like cast blast but will also prevent rust and stay there.
Old Mar 16, 2003 | 08:29 PM
LATNC3's Avatar
LATNC3
I used a silver rust paint....to prevent rusting.....they look good. i also brushed it on not spray. thicker coat than the spray....i would show you a pic but i got rid of them all i think....yah they all gone!!! trimclad!!
Rod
Old Mar 17, 2003 | 07:41 AM
Koz
Guest
Posts: n/a
Here is what Hi Heat Silver would look like
Ed Looks like you painted your frame Gloss-black.. Looks clean. What color did you paint the rest of the underbody?
Old Mar 17, 2003 | 08:35 AM
Koz
Guest
Posts: n/a
The rest of the underbody is mostly just spray undercoat.
:cheers:
Thanks Ed.. Did you spray the inside of the wheel wells with spray undercoat as well?
To BRAKE CALIPER PAINT
Old Mar 17, 2003 | 09:46 AM
Koz
Guest
Posts: n/a
That undercoat looks like it traps a lot of dirt. It has cusion to it to stop the nicks.. but doesn't look like it would clean up too easy.. Has that been your experience too..?
Old Mar 17, 2003 | 09:54 AM
norvalwilhelm's Avatar
norvalwilhelm
Mine came yellow cadmuim plated. I helped the color out with gold spray. My calipers don't show but I still like them to look good for anyone looking at the undercarriage.
Old Mar 17, 2003 | 03:24 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Brush-on RED.
