More horn craziness!?
Can anyone help me sort this out?
Jeff J
What if its grounding out deeper in the column. I think I need to understand how the big coil spring for tilt/tele affects the horn....
Tilt & Telescoping Column 69-82 Blowup Pic
and also download
Steering Wheel and Horn Parts Pic for the year C3 that you own; 69-75, 76, or 77-82.
The large coil spring should be part of the lower contact (#12 on the 69-75 pic; #1 on the 76, 77-82 pics)
The spring should rest on a plastic insulator (#1 "C" Ring Retainer shown on the blowup picture). This plastic part is quite important because it keeps the large spring from grounding on the Lock Plate #3 and blowing the horn. The retainer is available from GM dealers #7808385.
With the retainer in place, the spring should only rest on the three brass contacts that are part of the Horn Contact Carrier #4. The contacts extend up and through the Lock Plate #3. If the spring touches the lock plate, your horn will blow!
This might be the cause of your problems.
Thanks for the reply. Let me see if I understand this correctly now...
You said
<<With the retainer in place, the spring should only rest on the three
I assume you mean rest in the "c" ring retainer which would mean they wouldn't make contact until the horn button is pressed?
Also does this mean that it is normal for the small spring under the pushrod to be touching the lower contact metal at all times? It seems to me this is where the "actual" contact is made...
Here are some pics of where I'm at.
Does it look like anything is missing?
Thanks for the help
Jeff J
[Modified by jorall, 2:27 PM 3/18/2003]
If the spring contacts the lock plate your horn will blow. Since you are missing the plastic retainer, you can try the following. Take duct tape and cover the lock plate. Take an Exacto knife and cut out small windows in the duct tape at the three brass contacts that are sticking through the lock plate. Now your spring will only contact the brass contacts. Your horn should work correctly.
BTW, great pictures!
[Modified by Jim Shea, 9:08 PM 3/18/2003]
Where does the horn button and the small spring and rod come into play?
Thanks for the help
I have just sent you my paper entitled Horn Operation Diagnosis. It can also be found at http://www.corvettefaq.com under Steering.
Here is how the horn is supposed to work. There is a black ground wire coming from the horn relay that connects to the steering column. When that wire connects to the vehicle ground, the relay closes and the horn will blow. So when you depress your horn button, that ground circuit is completed from the black wire through your horn button, and then down through the steering column shaft, down to the steering gear, and into the frame and back to the battery.
The steering column has a flat (harmonica) connecter the connects to the vehicle wiring harness. The last wire in the steering column connecter is a black wire. The next is a pink wire. The next wire (the third one) is another black wire. This is the horn ground wire.
There should be continuity from that third wire up to the spring loaded eyelet plunger sticking up at the horn button upper contact on the steering wheel. (When the big spring just touches the brass contacts, you are only completing the circuit from the third wire to the eyelet plunger.)
Now when you press the horn button you should complete the circuit and there should be continuity from the third wire all the way to the lower end of the steering column steering shaft down by the steering gear.
So from what you describe, if the horn blows when the big spring just touches the brass horn contact, then the horn circuit must be completed further upstream on the steering column (i.e. a bad horn contact, a missing insulator, etc.)
Jim Shea
