72 Compression ratio and gas?
Old Mar 21, 2003 | 09:48 AM
Ki m Le's Avatar
Ki m Le
Default 72 Compression ratio and gas?
I have the base motor (350, 200HP). What would the compression ratio be? What grade of gas should be used?
Old Mar 21, 2003 | 09:55 AM
Ganey's Avatar
Ganey
Default Re: 72 Compression ratio and gas? (Ki m Le)
Spec. 8.5 & reg.
Old Mar 21, 2003 | 10:18 AM
GTR1999's Avatar
GTR1999
I always ran 89 octane without a problem.
Gary
Old Mar 21, 2003 | 11:06 AM
Ki m Le's Avatar
Ki m Le
So, mid grade is a winner! Thanks all.
Old Mar 21, 2003 | 10:01 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: 72 Compression ratio and gas? (Ganey)
Spec. 8.5 & reg.
:iagree:
Unless there's a problem like carbon build up or a rough edge in the combustion chamber, 87 octane should be fine as that's what it was designed to use. It won't hurt anything (or help anything either), other than your wallet, if you feel better using a higher octane though.
To 72 Compression ratio and gas?
