Lowered! with pics
Old Mar 23, 2003 | 05:07 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Lowered! with pics
so i finished up my spring/a arm bushing swap yesterday and took the 69 to hooters and met up with a couple guys from the club (sorry leg humpers, no pics with hooters girls on it)
Old Mar 23, 2003 | 05:10 PM
1Bad69's Avatar
1Bad69
Default Re: Lowered! with pics (Corzvette69)
Corey...nice pics but sorry dude...what did you lower? Was the front end higher than that before?
Old Mar 23, 2003 | 05:12 PM
QuickVet's Avatar
QuickVet
Default Re: Lowered! with pics (1bad69)
:lol: :lol: :lol: :lol: :lol: ohhhh, he will be glad to hear that :lol: :lol: :lol:
Old Mar 23, 2003 | 05:14 PM
69stingray's Avatar
69stingray
Nice looking Vette
Old Mar 23, 2003 | 05:16 PM
Corz's Avatar
Corz
i lowered the front about 2 inches.
i checked my car this morning and it got even lower.. so the pics might have been before the nose settled
here's with the stock springs
Old Mar 23, 2003 | 05:54 PM
PatsLs1vette's Avatar
PatsLs1vette
Looks good corey,gotta love that blue :yesnod: :thumbs:
Old Mar 23, 2003 | 06:04 PM
radwebster's Avatar
radwebster
:lolg:
Old Mar 23, 2003 | 06:09 PM
QuickVet's Avatar
QuickVet
Default Re: Lowered! with pics (radwebster)
car looks great corey :cheers:
Old Mar 23, 2003 | 06:22 PM
Corz's Avatar
Corz
Default Re: Lowered! with pics (patsnitrovette)
if it wasnt for yours, mine would probably still be white :leaving:
Old Mar 23, 2003 | 06:26 PM
Shark Racer's Avatar
Shark Racer
I agree Corz... that wheel gap is still a hell of a lot. See my sig. :) I enjoy collecting coins off the ground with my air dam. Those are after adjusting the springs?
-Steve
Old Mar 23, 2003 | 06:57 PM
Corz's Avatar
Corz
Default Re: Lowered! with pics (Pacin'California)
-Steve
the BALD 215/65 15s dont help the appearance... its a tad lower in the front then the rear, but the front looks higher because of the lower profile tires.
Old Mar 23, 2003 | 11:18 PM
litevette's Avatar
litevette
Pacin, what all did you do to get it so low?
Old Mar 24, 2003 | 12:56 AM
Corz's Avatar
Corz
Default Re: Lowered! with pics (litevette)
he's got dead bodies under the hood :conehead
550lbs springs with a fully loaded car
i have 460lb springs with one coil cut out
Old Mar 24, 2003 | 01:42 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Damn Cory, great looking car, I love the stance. :cheers:
Old Mar 24, 2003 | 01:44 AM
Shark Racer
Like Corz said, "fully loaded".
Iron heads, copper-brass rad, standard water pump and A/C give a lot of frontal weight.
Other than that, just running unbutchered 550 lb springs from VetteBrakes.
If I went w/ alum rad, alum water pump, dropped the A/C and had alum heads, I might expect a 1/4" increase in ride height from the weight savings.
The 550s will get you down VERY low though. Run them with a big block and you'll be a ground-scraper.
-Steve
Old Mar 24, 2003 | 05:29 AM
Mystery Machine's Avatar
Mystery Machine
Looks good. That white stripe is sweet looking! :thumbs:
Old Mar 24, 2003 | 12:41 PM
Corz's Avatar
Corz
Default Re: Lowered! with pics (Mystery Machine)
Thanks, i had to do something so people could tell my car apart from Pats :hat
To Lowered! with pics
Old Mar 24, 2003 | 12:50 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In VI Veteran
Looks the same to me :confused:
Old Mar 24, 2003 | 01:02 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Lowered! with pics (SnoDrgn)
I have 460lb springs with 1 1/4 coil cut out. It gives me 2 1/2 clearance to the bottom of my front spoiler.
My front fender lip is at 26 inches, with a 255/45/17 tire that measures 26 inches diameter. If anything, I wish it was about 1/2 - 1 inch higher. 26.5 - 27.0 fender height is about perfect for these cars with lower profile tires.
Nice to see that you finally got it done Corey.
Old Mar 24, 2003 | 06:06 PM
Corz's Avatar
Corz
Default Re: Lowered! with pics (BSeery)
mine is now 27 3/4th in the front. driver rear is 28 1/4 pass rear is 27 3/4ths
Im not sure how that happened :crazy:
