Hooker Sidepipe - Glasspack vs. Reverse Flow?
Old Mar 25, 2003 | 07:56 AM
pingdashf's Avatar
pingdashf
Default Hooker Sidepipe - Glasspack vs. Reverse Flow?
I am looking into getting some hooker sidepipes for her so she can sound meaner than she is. I am looking at going with a complete hooker setup even though I have seen some people go with other brands for the side pipes and mufflers. I have two options for the muffler inserts, reverse flow or glasspack. Whats the differences in sound and performance? I guess performance isn't a huge issue since they are easily removeable for racing?
And, while we're on it, why wouldn't I use hooker for the pipes and mufflers and what are the other options?
And, this little guy made me yawn: :yawn:
Old Mar 25, 2003 | 08:35 AM
MassVette's Avatar
MassVette
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (pingdashf)
Hooker mufflers cost me 95 h.p. on my 502 dyno runs- I'm NOT kidding. If you want Hooker side pipes, use the JCL spiral baffles, IMHO.
my 2c.
Old Mar 25, 2003 | 09:04 AM
groovyjay's Avatar
groovyjay
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (MassVette)
JCL Baffles here :iagree: :steering:
Old Mar 25, 2003 | 09:17 AM
69ttop502's Avatar
69ttop502
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (groovyjay)
I lost 96 hp with the reverse flows. See my dyno chart at spiralturbospecialties.com. Get the JCL baffles, do not even bother with the Hooker mufflers. :iagree:
Old Mar 25, 2003 | 09:24 AM
1Bad69's Avatar
1Bad69
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (69ttop502)
JCL.... :iagree:
Old Mar 25, 2003 | 09:58 AM
WA 2 FST's Avatar
WA 2 FST
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (1bad69)
I am another "convert" to the JCL inserts. I had the Hooker glasspacks in mine for all of 40 miles. Absolutely _killed_ power...and I have a mild BB. If your SB is bone stock, then it may not be a big deal, but I would not label either of the Hooker muffler offerings as "performance-oriented".
I took mine out and ran open pipes and got all my power back...til it just drove me nuts, and then I installed the JCLs. I can't tell of any power loss compared to open pipes. I'm sure there was some but minimal. With the Hooker glasspacks, the engine almost wouldn't rev under load past 4000rpm.
As far as the Hookers or any baffle/muffler/insert being "easily removeable for racing"... that's a crock. I've had my sidetubes off twice now and its a PITA compared to what it looks like the job should be.
Do it once, do it right and get the Hooker headers and sidetubes and then get the JCL baffles. :D
Old Mar 25, 2003 | 10:16 AM
BeaterShark's Avatar
BeaterShark
The reverse flow are quiet and are extremely restrictive.
The glasspacks are a bit louder and are very restrictive.
If your motor is stock and you plan on keeping it that way, the glasspacks will probably not cost you much, if any HP. The problem is that the glasspack have a 1 3/4" - 2" inner diameter with a louvered core. A louvered core is where the "holes" are created and the metal is angled into the pipe. This effectively makes the inner diameter smaller.
Look at the motors those guys have who lost 95 HP. They have almost 50% more displacement than you.
If you are a little creative or can find a creative muffler shop, you can modify some better glasspack inserts (Thrush) or auger style to work and you will get out for less money than the Hooker ($140) or the JCL ($300).
Old Mar 26, 2003 | 10:26 AM
pingdashf's Avatar
pingdashf
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (BeaterShark)
Right now I am bone stock, but the plan is to change that. I want to add the sidepipes, upgrade my tires, suspension and brakes, and then I'll have a good house for a better engine.
Looks like JCL is the clear favorite.
Old Mar 26, 2003 | 11:09 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'm runnin open pipes.. but they are a little bit on the loud side..
The best muffler on the market are definetely the JCL's STS Baffles...especially if uncapped
Old Mar 26, 2003 | 02:00 PM
pingdashf's Avatar
pingdashf
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (GrandSportC3)
Where does one get info on and purchase these JCLs?
Old Mar 26, 2003 | 02:09 PM
groovyjay's Avatar
groovyjay
Here ya go:
http://www.spiralturbobaffles.com/
:cheers:
Old Mar 26, 2003 | 05:47 PM
Schmucker's Avatar
Schmucker
Problem is that those JCL baffles are expensive.
Old Mar 26, 2003 | 09:46 PM
Clink69's Avatar
Clink69
JCLs here... Had both teh glasspack and Reverseflows. the Reverse flows are OK if you have lower HP... reverse flows suck in all cases.. Car sounds like a minivan..
Old Mar 26, 2003 | 11:12 PM
pingdashf's Avatar
pingdashf
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (Clink69)
...Car sounds like a minivan...
On my way to Buds Creek (the local strip) there is a giant billboard with a minvan and the tag line "245 Horses". I :cry everytime I see it because a &*$&*#&* minivan has more HP than my vette :mad
Of course, that doesn't make SOUNDING like one any more justifiable.
Old Mar 26, 2003 | 11:59 PM
454Can-Am's Avatar
454Can-Am
:iagree:
JCL is the only way to go !!!!!!!!!!
:chevy
Old Mar 27, 2003 | 01:30 AM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (Schmucker)
They are not cheap, but considering I lost no more than 6 of my 483 rear wheel horsepower compared to open headers, a good investment. Loud, inexpensive mufflers would save me money but would lose me a whole lot of horse power. How much would I have to spend and how much more hassle would it be to install additional go fast goodies to get the power back compared to simply using JCL's well designed and proven inserts?
Chuck
Old Mar 27, 2003 | 12:46 PM
BeaterShark
Default Re: Hooker Sidepipe - Glasspack vs. Reverse Flow? (Chuck Harmon)
I dissagree with this statement. Perferated core glasspack mufflers are really hard to beat for performance. After all, this is what most "racing" bullet mufflers are.
Sure it takes some effort to find the ones you want and then more effort to get them in the side tubes, but it also takes some effort to swap cams and you wont see me paying someone to do that.
IMHO, if you're willing to spend the money and you don't want to deal with the work required in getting free-flowing mufflers in the side tubes, go with the JCL's. But to think that is the ONLY way to get performance out of Hooker side pipes is just not true.
To Hooker Sidepipe - Glasspack vs. Reverse Flow?
Old Mar 27, 2003 | 02:05 PM
68427's Avatar
68427
I bought JCL baffles and side pipes. Quality is first rate and they fit perfect. I am using Stahl headers and am impressed with the quality and fit of those as well.
Old Mar 27, 2003 | 02:41 PM
Chuck Harmon
I also disagree. Yes, you can install perforated glass packs that will be just as free flowing (3" clear inside diameter), BUT, they are MUCH louder than the JCL's.
Chuck
Old Mar 27, 2003 | 03:04 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Chuck
And in the opinion of some of us, sound MUCH better :cheers:
