1968 Front Wheel Hubs
Old Mar 25, 2003 | 11:00 PM
mpettus's Avatar
mpettus
Default 1968 Front Wheel Hubs
Does anyone know if there is a difference between a 68 front wheel hub and other third gen front hubs? I have been told recently that the 68 hub is a one year only design. The reason I ask is that I puchased a hub from a swap awhile back in preperation to replace mine, figuring that they would be interchangable with any C3. If there is a difference, does anyone know the critical dimensions to determine if I purchased a 68 or not?
Thank You
Matt
68 Convertible
Old Mar 25, 2003 | 11:19 PM
redvetracr's Avatar
redvetracr
Default Re: 1968 Front Wheel Hubs (mpettus)
I "think" the 65-68 hub is the same, the difference is in the spindle, the 68 spindle takes larger bolts for mounting the steering arms. ...redvetracr
Old Mar 25, 2003 | 11:45 PM
wombvette's Avatar
wombvette
Default Re: 1968 Front Wheel Hubs (redvetracr)
Yes, and 69-up has larger bearings.
Old Mar 26, 2003 | 08:39 AM
Robd's Avatar
Robd
redvetracr is correct, hub should be the same the difference is in the spindle.
Old Mar 26, 2003 | 06:52 PM
mpettus's Avatar
mpettus
Thanks for the info.
Matt
68 Convertible
Old Mar 26, 2003 | 09:45 PM
tracdogg2's Avatar
tracdogg2
The hub and spindle are different. 65 - 68 are the same, 69-82 are the same. I just finished swapping to larger bearing spindles and hub/rotors. Cost less than buying two 68 hubs. 69 -82 backing plates have a larger center hole. The steering arms and caliper mounting brackets all interchange 65 - 82.
Mike
To 1968 Front Wheel Hubs
