Jacking car up
Old Mar 27, 2003 | 07:08 PM
battsup's Avatar
battsup
Default Jacking car up
Where should i place the jack? im lifting the rear end up so i can remove the wheels and inspect the brakes.
Old Mar 27, 2003 | 07:13 PM
79VetteMike's Avatar
79VetteMike
Default Re: Jacking car up (battsup)
I usually put the jack under the pumpkin, but I suppose it depends on what kind of jack you are using.
Old Mar 27, 2003 | 07:15 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I use the pumpkin also.
Old Mar 27, 2003 | 07:16 PM
battsup's Avatar
battsup
Default Re: Jacking car up (79VetteMike)
The jack is a floor jack( the ones with the wheels and the long handle)
what is a pumpkin?
Old Mar 27, 2003 | 07:43 PM
R. Bruno's Avatar
R. Bruno
what is a pumpkin?
[/QUOTE]
Some cars have pumpkins although some of the earlier cars had cantalopes or honeydews. It is the rear differential :D I jack one side at a time at the frame about 6 inches in front of the wheels, but others jack from the pumpkin.
Old Mar 27, 2003 | 08:03 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: Jacking car up (R. Bruno)
what is a pumpkin?
The honey dews got my laughing HAHAHAHAA :jester :jester :jester :jester
Old Mar 27, 2003 | 08:12 PM
jerryp58's Avatar
jerryp58
Here are the published jack points (and lift and jack stand points)... http://users.erols.com/jerryp58/corvette/jackpts.jpg
If you use these points and want to get the car fairly high, I will work my way from side to side raising each side a little higher as I go along.
To Jacking car up
