Riveted Rotors???
Old Mar 27, 2003 | 07:22 PM
PB82CE's Avatar
PB82CE
Default Riveted Rotors???
OK, I take the Vette in today to have the calipers, pads and rotors replaced and the mechanic tells me that the original rotors are still on the car, because they were riveted on?? Back in 1982??
Did Chevy actually do that?? Why??
Cost me an extra 2 hours worth of labor to get them off, and just wondered what was the reason for riveting them on, and if anyone else had the same problem... :confused:
[Modified by PB82CE, 6:23 PM 3/27/2003]
Old Mar 27, 2003 | 07:26 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: Riveted Rotors??? (PB82CE)
The rotors are riveted on, because I believe they are manufactured as a unit. The riveting allows for closer tolerances when it comes to runout.
The above may not be entirely correct, but that's how I understand it.
When I rebuilt my front end, I bought a carbide bit and I drilled out the rivets. It does not take anywhere near two hours. I'm sorry he charged you that. To drill out the rotors took this first timer fifteen minutes. Not a big deal.
Next time, try doing the brakes yourself. It's easy and a lot less expensive than having someone else do it for you. You could do the whole thing in a shade over an hour.
:cheers:
Old Mar 27, 2003 | 07:28 PM
79VetteMike's Avatar
79VetteMike
Yes, they were riveted at the factory. Anyone that doesn't have the rivets has had the rotors off at least once. And 2 hours extra labor is a fair price because it's a real PITA to get them off.
Old Mar 27, 2003 | 07:29 PM
PB82CE's Avatar
PB82CE
Default Re: Riveted Rotors??? (joeveto)
Joe, I only wish I had the time to "Do it myself"
I have the tools, but the time is worth more to me...
Old Mar 27, 2003 | 07:30 PM
79VetteMike
Default Re: Riveted Rotors??? (79VetteMike)
Well, I burnt up a drill getting them out. Maybe others have had better luck. I agree, try doing it yourself next time. Mechanics easily take advantage of people that don't know any better.
Old Mar 27, 2003 | 07:34 PM
PB82CE's Avatar
PB82CE
Dont get me wrong, I'm not bitchin about the cost for the two hours, for me it was worth it. Just wondering why they (CHEVY-GM) would do that?? :confused:
Old Mar 27, 2003 | 09:44 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Chevy did it because when the rotors are NOT riveted on and you bleed the brakes the rotor moves the pistons move ( remember the .007" runout rule? ) and pumps air into the system. You cannot, well it's really hard, to get a good bleed with the rotors unriveted. O-Ring calipers will help tho...
I actually recommend tapping the hubs for a 3/8x16 and using screws to hold the rotors steady, much better bleed that way...
Old Mar 27, 2003 | 09:52 PM
joeveto's Avatar
joeveto
Cruise-In V Veteran
I agree with 427. You have to use the lug nuts to hold the rotor in place.
And I understand the whole time vs money thing. I've sent my car into the shop on more than one occasion, when I was too busy to mess with it. But then I inevitably get taken advantage of. So unless it's really bad, I try it on my own.
:cheers:
Old Mar 28, 2003 | 12:16 PM
GTR1999's Avatar
GTR1999
Were the rotors worn out? Even new rotors can have too much runout. Be sure they check the runout before you take the car.
Good luck,
Gary
Old Mar 28, 2003 | 05:43 PM
timbo79's Avatar
timbo79
Default Re: Riveted Rotors??? (gtr1999)
Kind of stinks, huh..
I just went through this... use hardened drill bit.. very easy then.
From what I understand, it was an economics thing. With the rotors riveted it saved time on the assembly line. 1 motion versus 2 or 3. Also, the General sold complete units with hub, etc... as replacement (they still do). Lugs will hold the new rotors on (like a modern car) Once you do this, you won't have to do it again.
Good Luck
Old Mar 28, 2003 | 06:16 PM
PB82CE's Avatar
PB82CE
The rotors werent really that bad as far as wear goes, but I had one or two that were warped, and rotting out from the inside. We replaced all 4 rotors and calipers, and the braking now, is great. :yesnod:
Old Mar 29, 2003 | 12:23 PM
LemansBlue68's Avatar
LemansBlue68
The rotors were riveted on at the factory because they were turned along with the axle shaft as unit. This minimized rotor run out when installed. They obviously don't need re-riveted but do make sure that the rotor runout is held to a minimum when they're reinstalled. Check by holding the rotor in place with the lugnuts and use a dial indicator to make sure everything is in spec. If out, check for dirt or rust on the hub or rotor. If there isn't anything obvious that woud affect runout, use some shim stock to try to get things back in line. If that still doesn't work whoever turned the rotors didn't get them true and should re-do them.
To Riveted Rotors???
