Dyno Max Exhaust Part Numbers
Old Mar 30, 2003 | 01:02 PM
Northwest79's Avatar
Northwest79
Default Dyno Max Exhaust Part Numbers
Heyas Folks
I am trying to figure out exactly which part numbers I need to upgrade my
79 Vette Exhaust System with Dyno Max headers and mufflers.
I want the the Ultraflow SS Mufflers.
Prices range from ~$100 to ~$160 for what seems to be the same Muffler
but everyone uses their own part numbers so it is hard to compare apples
to apples...
I think that the muffler I need is #17264 which is a 14" muffler with 2 1/2 inch inlets and offset 2 1/4 outlet.
As far as headers go, I would like the low end torque (emission control is not an issue where I live). I was looking at their ceramic coated headers, they also have some "block huggers" which look like they would be an easy install.
I am pretty new to this kinda thing, I have read the exhaust faq ... just looking for some more perspective !
Cheers ! :hat
Old Mar 30, 2003 | 04:44 PM
tnt76vette's Avatar
tnt76vette
Default Re: Dyno Max Exhaust Part Numbers (Northwest79)
My $.02 worth..... I think that most folks here will tell ya that shorty or block hugger headers dont flow much better than the stock Ram Horns. Dynomax Ceramicoats in Full Length run about 230 bucks from either Jeg', Summit, or others. Those or others like them from other manufacturers, seem to be the hot ticket today. As far as mufflers go, thats pretty much personal preference. I went with Mid-Am chambered pipes. Good Luck whatever you choose......... :yesnod:
Old Mar 30, 2003 | 09:55 PM
dlw's Avatar
dlw
Try their web site. Dynomax.com I think
Old Mar 31, 2003 | 12:21 AM
Northwest79
Default Re: Dyno Max Exhaust Part Numbers (dlw)
yea.. I have been there ... but I can't figure out the part number for the headers.... I am a newb at this kinda thing...
Old Mar 31, 2003 | 06:45 AM
79VetteMike's Avatar
79VetteMike
Default Re: Dyno Max Exhaust Part Numbers (tnt76vette)
I totally agree. Just call Jeg's or Summit and they can help you. They do all have their own part numbers and I think it is so it is harder to comparison shop. I have Flowmaster 40's and I lovethem. They are kinda loud though. You should be able to use the same size inlet as the outlet. I believe mine are offset inlet and centered outlet. Hope that helps.
Old Apr 5, 2003 | 07:52 PM
Northwest79
Default Re: Dyno Max Exhaust Part Numbers (79VetteMike)
For anyone else who may be interested. Got a reply from Dynomax!
1979 SB 350
Dynomax Ceramic coated header Part number#86008.
Dynomax Ultra Flo Mufflers Part #17264 Ultra Flo
Old Apr 5, 2003 | 11:28 PM
isosceles's Avatar
isosceles
What kit are you using between the headers and the mufflers? Is that kit that includes the pipes?
Old Apr 5, 2003 | 11:46 PM
74ZZ430's Avatar
74ZZ430
On my 74 I used 17261 and 17262 which are 2 1/2 in and out , offset offset. and had the muffler shop bend a couple of stock looking downspouts out of stainless. The reason I used these mufflers is that they are 3/4 of an inch narrower than the stock muffler giving me about an inch clearance on each side of the muffler. These mufflers come with a bracket welded on the end that is easy to cut off. The down side of using these part numbers are they were originally designed to be a direct fit on the Mustang. These mufflers are fairly queit at idle and cruise but loud at full throttle, I'm having an X pipe install next week.
Old Apr 6, 2003 | 01:39 AM
Glensgages's Avatar
Glensgages
Default Re: Dyno Max Exhaust Part Numbers (74ZZ430)
Did you get your Vette a tetanus shot? :p:
Old Apr 6, 2003 | 01:20 PM
Northwest79
Default Re: Dyno Max Exhaust Part Numbers (Glensgages)
No kit... just gonna straight pipe from the headers to the mufflers.. for now.
To Dyno Max Exhaust Part Numbers
