pulley ping and knock
Old Mar 30, 2003 | 04:04 PM
tophorse's Avatar
tophorse
Default pulley ping and knock
My 87 has some light pinging from either pulley or cranshaft when the engine rpm go below 900/1000 rpm. When I just start the car there is no pinging but after about 30 seconds the rpm drop to 600 rpm, then the metalic pinging comes. The pinging will go away if I tap accelerator panel. If I put the gear on the rpm drop to 600/700 rpm, the pinging will appear again. The pinging go away if I push the accelerator. By the way, I just finish my timing light adjustment. The only time I touch pulley is when I try to set the TDC#1. I did use a sucket to turn the pulley. I always turn the pulley in clockwise direction when I stand infront of the car.
Angus
