gm rpo codes
Old Mar 31, 2003 | 03:52 AM
sfields1's Avatar
sfields1
Default gm rpo codes
hi,'
a friend of mine has a c3 and asked me where the sticker is for the codes gm uses for their option codes, on my c4 is is under the console lid does anyone know where it is located his is a 75
thanx :flag
Old Mar 31, 2003 | 04:14 AM
Shark Racer's Avatar
Shark Racer
Default Re: gm rpo codes (sfields1)
Paint codes- if you open the driver's side door, it should be riveted in in there near where the door angles. About the size of a 3x5 card.
As far as options- the only hope is the build sheet, which MAY be on top of the gas tank. Whether or not it's legible depends on how fate treated your car.
-Steve
Old Mar 31, 2003 | 07:25 AM
GaryS's Avatar
GaryS
I assume you are talking about the codes for that particular car. As mentioned, each car, starting in 67 had a tank sticker affixed to the top of the gas tank. Others have had luck finding a folded copy between the speedo and tach or other parts of the instrucment cluster.
Gary
Old Mar 31, 2003 | 04:30 PM
fauxrs's Avatar
fauxrs
hi,'
thanx :flag
as alluded to in the other two posts - There is NO sticker on a C3 like that on your C4 - your only chance is to find the "Build sheet" located in various spots but most often on top of the fuel tank - or occasionally somewhere under the seat (only heard of this once or twice.)
To gm rpo codes
