What type of sump
Old Apr 2, 2003 | 01:41 AM
maskmang's Avatar
maskmang
4th Gear
Default What type of sump
I am currently building a 383, which should put out roughly 450hp. What type of sump would I need to put on to the engine. Engine will be be in a 68 vette with power steering. Or would the standard sump be good enough ie no windage tray.
Old Apr 2, 2003 | 03:49 AM
1979toy's Avatar
1979toy
Default Re: What type of sump (maskmang)
The standard oil pan will work fine, but as long as you're throwing money at it why not step up to an aftermarket pan to keep the oil away from the crankshaft. The depth added by one of the street 7 quart pans is not a problem with ground clearance for most of the people running them. You wouldn't want to be losing potential horsepower on those hard accelerations or tight turns. :bb
