Bonding Adhesive?
Old Apr 2, 2003 | 01:11 PM
Ki m Le's Avatar
Ki m Le
Default Bonding Adhesive?
I'm about to put the front clip on a 72. How much adhesive, do I need to get? I also need some extra adhesive to replace the Header bar too!
Old Apr 2, 2003 | 03:31 PM
wombvette's Avatar
wombvette
Default Re: Bonding Adhesive? (Ki m Le)
About 2 quarts.
Old Apr 2, 2003 | 04:07 PM
LakotasRose's Avatar
LakotasRose
Be really careful with that stuff!!!!!!!!!
When we were doing my rear bumper Hubby put just alittle too much on..and when we were cranking down the bolts ..it dripped down and got in his hair!!!!!! WHAT a chore to get that stuff out!!!!!!!!!!!!!!!!!!!!!! :eek:
Old Apr 2, 2003 | 09:30 PM
DVG73's Avatar
DVG73
What brand of adhesive are you going to use?
Old Apr 3, 2003 | 12:21 AM
NHvette's Avatar
NHvette
Default Re: Bonding Adhesive? (LakotasRose)
Did you see my "adhesive in my eye :eek:" post ? http://forums.corvetteforum.com/zerothread?id=518571
DOHHH !
I am using this: Evercoat 870
I have about a 1/2 quart left. I was hoping another quart would get the front clip bonded on. There is another header bar post right now. I would consider
a more flexible adhesive for the header bar.
:seeya
[Modified by NHvette, 12:23 AM 4/3/2003]
Old Apr 3, 2003 | 05:43 AM
Mystery Machine's Avatar
Mystery Machine
Default Re: Bonding Adhesive? (NHvette)
I just used "SMC" (I'm not sure if that's the name of the product or just the name of the material) to put on the fornt bumper on my '73 and it seems to have held fine so far. :thumbs:
Old Apr 3, 2003 | 06:41 AM
Dalannex's Avatar
Dalannex
I use the evercoat 2 part epoxy bonding adhesive with a 1:1 mixing ratio because it is recommended for use on everything including metal to fiberglass bonding. You will probably need a couple of quarts.
-Justin
Old Apr 3, 2003 | 11:00 AM
Ki m Le's Avatar
Ki m Le
Default Re: Bonding Adhesive? (Dalannex)
Dalannex,
What do you mean 1:1 mixture? bonding compound:hardener?
Thanks for all repliers
Old Apr 4, 2003 | 11:15 AM
NHvette's Avatar
NHvette
-Justin
Justin - what is the Evrecoat part # for the 1:1 stuff ? Is it hard or flexible ?
To Bonding Adhesive?
