Plastic Liner inside tank??
Old Apr 2, 2003 | 09:31 PM
CDaniel525's Avatar
CDaniel525
Default Plastic Liner inside tank??
I heard some c3's have a plastic liner inside the tank? I was curious if '74's had this liner or if its just all steel. I wanna know cause I am planning on welding in 2 fittings as new pickups.
Chris
Old Apr 2, 2003 | 09:51 PM
wombvette's Avatar
wombvette
Default Re: Plastic Liner inside tank?? (74VETTE)
Not in 74, came later.
Old Apr 2, 2003 | 11:08 PM
CDaniel525's Avatar
CDaniel525
Default Re: Plastic Liner inside tank?? (wombvette)
Thank you sir!
Old Apr 3, 2003 | 05:09 PM
QuickVet's Avatar
QuickVet
what years did this liner get put in?
Old Apr 5, 2003 | 02:15 PM
Paul L's Avatar
Paul L
Default Re: Plastic Liner inside tank?? (QuickVet)
This might be useful.
In 1975 the Chevrolet Corvette was unable to meet FMVSS 301 and not leak more than one ounce of gasoline a minute after a 30 mile per hour rear end moving barrier crash. GM's solution was to introduce a rubber bladder which provided the necessary protection against gas spillage inasmuch as the tank is located in the crush zone approximately 8 inches from the rear bumper. The history of bladders in competition race cars and in aircraft has been well documented with a variety of problems: deterioration, condensation, folding, cracking and the like. General Motors in 1978 introduced one of the safest gas tanks in the U.S. in its Corvette line by replacing the problematic rubber bladder with a High Density Poly-Ethylene ["HDPE"] liner.
HDPE is a common material for gas tanks today and an overwhelming number of safely positioned tanks on the road today are made of this plastic. It is capable of taking heavy blows and is slow to burn. It has proven itself as an automotive construction material in a number of applications.
Because the gas tank on the Corvette is directly in the crush zone for a rear impact, General Motors engineers encapsulated the HDPE tank within a standard metal tank and created a double-walled tank that has performed extremely well since 1978.
Based on the absence of fire claims from rear-end collisions suffered by Corvettes, and the vehicle's ability to be repeatedly certified by General Motors in compliance with FMVSS 301 for every production year since 1978, there is good reason to believe that a similar style HDPE/metal tank would enhance fuel system integrity of GM pickups with side saddle tanks.
Old Apr 5, 2003 | 02:43 PM
norvalwilhelm's Avatar
norvalwilhelm
I took the bladder out of my 75 and left it out. I silver brazed 2 half inch outlets to the bottom of the tank. I ran each of the outlets to a large filter then into a high pressure holley pump. I have 2 of everything just in case one fails.
Silver brazing is the easiest to do for installing outlets.
If you need the procedure just ask
Old Apr 5, 2003 | 02:56 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Plastic Liner inside tank?? (paul79)
Sounds like we should upgrade to a 78 or later tank when the old one goes.
There has been some discussion here about going to a racing type fuel cell. I notice there are 16gal circle track aviation foam filled fuel cells in the Jegs catalog for $210. I wonder if this would be even safer.
Dieing in a fire because some soccer mom in a minivan rear-ends me is an extremely scary proposition.
[Modified by turtlevette, 4:39 PM 4/5/2003]
Old Apr 5, 2003 | 06:14 PM
CDaniel525's Avatar
CDaniel525
Default Re: Plastic Liner inside tank?? (norvalwilhelm)
norval....if you could explain that procedure, id really like to hear it in case I can do it myself rather than let someone else do it :cool:
when you say silver brazing, do you mean by using acetyline and the brazing rods used in refrigeration pipes of air conditioning?? if so, im set to do it cause my dad owns a HVAC company and know how to do all the stuff.
thanks
chris
Old Apr 6, 2003 | 09:36 AM
Ganey's Avatar
Ganey
Starting in 75 Corvettes used a heavy rubber bladder like those used in race cars encased in a ribbed steel housing.
Remember race cars have safety equip.!
:cool:
Old Apr 6, 2003 | 01:39 PM
norvalwilhelm
74vette Gas tanks can be safely welded with an open flame if you take percautions. First of course is to remove all cover plates and the fuel filter and of course drain all gas from the tank.
I then take the shop vac and turn the hoses around so it blows instead of sucks and put it in the tank. You can let it pump air through the tank for as little as 5 minutes but to be really safe leave it 1/2 hour.
It is now safe to use anything you want on the tank. Pass a open flame in the opening and I guarantee if you did the vacuum thing nothing will happen. My son worked for a summer term at a gas tank repair shop and they thought 5 nimutes was more then enough.
To install a new fitting drill a hole in the tank, clean the area to be welded very clean with emery paper, install the fitting in the hole and then using either oxy acetaylene or just a plumbers acetaylene tank braze it with the same stuff that air conditioners use. I persoanlly use silver braze wire and flux but the stuff used for air conditioners works fine.
I have done both my corvette and the mustang's tanks with dual outlets at the lowest corners on each without a problem.
I have also repaired many tanks over the years with a penny and a open flame.
Old Apr 6, 2003 | 02:06 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Plastic Liner inside tank?? (Ganey)
So the bladder actually began an '75 and '78 was just an upgrade in the bladder's design/materials? (To clarify)
-Chris
Old Apr 6, 2003 | 04:42 PM
Paul L's Avatar
Paul L
Default Re: Plastic Liner inside tank?? (RUXperienced)
That is correct. But it was a major upgrade in 1978. There is a world of difference between rubber and HDPE.
http://www.plasticsmachining.com/mag...06/omnium.html
[Modified by paul79, 4:50 PM 4/6/2003]
Old Apr 7, 2003 | 01:12 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Do the HDPE liners collapse like the rubber ones did?
I remember seeing everyone removing their liners awhile back. I don't want to unless it will solve a problem.
Old Apr 9, 2003 | 06:52 PM
QuickVet's Avatar
QuickVet
Default Re: Plastic Liner inside tank?? (Desertdawg)
how exactly do you remove the liner, or part of it?
Old Apr 9, 2003 | 06:57 PM
page62's Avatar
page62
If I'm not mistaken, HDPE is a rigid material. And this also explains why it's impossible to get new 78-82 tanks!
Old Apr 9, 2003 | 09:23 PM
Paul L's Avatar
Paul L
Default Re: Plastic Liner inside tank?? (page62)
That is correct. It is a rigid plastic composite. And to remanufacture a tank using it/around it would be very expensive. The rubber insert is more pliable: moldable. This thread is instructive as it explains why all the Corvette catalogues list tanks to 1977 and then....stop.
Old Apr 9, 2003 | 10:26 PM
Ganey's Avatar
Ganey
There is no reason to remove it w/o a problem. Remember race cars have safety equip.!
Old Apr 9, 2003 | 11:25 PM
bigvette1's Avatar
bigvette1
As long as we are talking tanks, what years have that sock or so called filter on the pickup that plugs with sediment etc. and cut down the fuel flow. I have a 73. Can the sock be cleaned or pulled out without droppoing the tank? Thanks for the advice.
JP
Old Apr 10, 2003 | 01:57 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Plastic Liner inside tank?? (bigvette1)
Yes the sock and pickup can be removed right through the top of the tank, without removing the tank from the vette. The sock is easily replaced. and after 20 plus years, its a good idea to do it...
I think there is a tech article somewhere. But right now I can't find it...
I'm glad to hear the the later years, liner is rigid, that means that I don't need to remove it for fear of it collapsing. :cheers:
To Plastic Liner inside tank??
