1982 owners...error code #43
Old Apr 8, 2003 | 01:48 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default 1982 owners...error code #43
Ok, I pulled the error code off of my vette tonight. I know that #43 is the ESC (Electronic Spark Control) problem/Knock sensor.
And the crossfireforum has a nice help page devoted to error codes. Here is what it says to do.
Connect a timing light to the no 1 ignition wire. Start the engine and notice the timing, then with a hammer strike the engine block and check if the timing retards. If not replace the knock sensor. The ESC almost never goes bad. If this still doesn't help replace the ESC.
How do you get a hammer in there to pound on the block :lol: :lol: :lol:
And do I need to replace this right now? Or will it hurt to drive for now without it working? I get no Knocking that I can hear.
Old Apr 8, 2003 | 04:51 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 1982 owners...error code #43 (Desertdawg)
Dawg,
Check for a loose or dirty connection at either the knock sensor (pass side low on the block) or at the connector from the ESC, it's on the back of the ecm, they tend do get dirty or wiggle loose.
If that's okay andit still doesn't retard timing (you can also hit the exhaust manifold) try to replace the knock sensor. The 82 has a different sensor from all the other years though.
The knock sensor is screwed into the pass side block drain so you don't want to replace it on a hot engine :)
If your esc turns out to be shot, I have a spare one
Marck
[Modified by Twin_Turbo, 3:53 AM 4/8/2003]
Old Apr 9, 2003 | 01:49 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: 1982 owners...error code #43 (Twin_Turbo)
Thanks Marck,
Is it OK if i don't fix this right away? Will it hurt anything?
I dont hear any knocking at all now...
Old Apr 9, 2003 | 04:44 AM
Twin_Turbo's Avatar
Twin_Turbo
If you get into a situation of heavy knock it could really hurt the engine.
Old Apr 10, 2003 | 02:08 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Ok, Thanks again Marck.
I will let you kow what I find, as soon as I can get to it....
To 1982 owners...error code #43
