Paint (Kinda OT)
Old Apr 3, 2003 | 08:37 AM
theandies's Avatar
theandies
Default Paint (Kinda OT)
I am almost complete with my model of a 1971 (Actually the box says 1972 but the interior has the fiber optics on the center console) My paint is War Bonnett Yellow and I would love to paint it that color. Any art people out there? What colors do I need to mix to make WBY? Use the picture in my sig to match it. Thanks and as soon as it is complete I'll post some pictures.
John
Old Apr 3, 2003 | 11:33 AM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Default Re: Paint (theandies)
If it were me I'd take the paint code to the paint supply store and have them mix me up a small aerosol can of touch-up paint. :yesnod:
Old Apr 3, 2003 | 12:17 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
John,
Sure seems like there was an F-Body (camaro) in the 90's that was a very similar color to yours and had a black roof. I'd swear I've seen one. Go to the dealer and look a paint chips and then buy a can of touch up spray for the closest color you can find.
Or have a paint shop mix you up a pint of war bonnet yellow. Mixing your own will be hard to get a match.
Old Apr 3, 2003 | 06:02 PM
theandies's Avatar
theandies
Default Re: Paint (74-Roadster)
John,
I thought of doing that but I want to use Testors enamal. I know someone that paints or is into art can tell which colors I would need to blend to come up with WBY. If I don't get any results then I will do that. I don't want to buy a whole buch of paint that I'll only use once. BTW my model looks :cool: I forgot about it when we moved and found it in a box the other day.
Thanks Glenn
Old Apr 3, 2003 | 11:37 PM
74-Roadster
St. Jude Donor '06
There's a 90's Camaro in our parking lot that looks like war bonnet yellow. I'l get the details and see if duplicolor makes a spray can of it for you.
The sad part is, I'm still working on the same model you saw 15 months ago. :bb I changed the rear flares and I've cut the front clip loose to make it full tilt . . . I may be slow, but I'm good!!! :D :D :cheers:
Old Apr 4, 2003 | 09:47 AM
theandies's Avatar
theandies
Thanks Glenn,
I am the same way, I take my time and make it right. I think I have put it together and taken it apart (without glue) a million times to get all the paint just right. Last night I spent 2 hours painting the rear tail light. I am actually painting the chrome inserts on the tail light lens and also the backup lights that are in the center of the lens......how **** is that????? I will probably do it over because I didn't like the results (maybe, I haven't looked at it today so I may change my mind)
Old Apr 4, 2003 | 12:25 PM
JJ Deuce's Avatar
JJ Deuce
check out this link. They make paint specifically for models that matches the OE colors.
http://ourworld.cs.com/mcwautofinishes/
Old Apr 4, 2003 | 01:13 PM
theandies's Avatar
theandies
Default Re: Paint (Jeff 6T9)
Thanks Jeff I'll check it out when I get home. My work browser is filtering that site for some reason?????
[Modified by theandies, 12:15 PM 4/4/2003]
Old Apr 4, 2003 | 01:56 PM
Corz's Avatar
Corz
you can get paint to match in enamel. go to the paint supply store and just ask for the spray can in enamel. it should only cost about 12 bucks, but it will match :thumbs:
To Paint (Kinda OT)
