Turn Signal Question
Old Apr 4, 2003 | 11:00 PM
Randy 71's Avatar
Randy 71
Default Turn Signal Question
Ok, All light bulb are working properly. Just started a month ago. When using the turn signal, the signal indicater flashes really, really fast. Sometimes faster than other times. No consistency in the speed of flashing. Mater of fact sometimes it will start flashing normally, then speed up. Any ideas?
Old Apr 4, 2003 | 11:26 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Turn Signal Question (Randy 71)
Possibly a bad connection, failing bulb, or failing flasher. CHange the easiest and cheapest first. Flasher
And register your 71 at http://www.71corvette.com. Or else, nothing will fix it.... :jester
[Modified by 71,454,4spd, 10:27 PM 4/4/2003]
Old Apr 5, 2003 | 12:37 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Turn Signal Question (71,454,4spd)
If you haven't already, first check that every other bulb is operational, if I'm not mistaken another dead bulb in the circuit can cause a working one to flash faster.
-Chris
Edit: damn it, I'm useless. Just noticed you said they're all operational, well 71.454,4spd's advice sounds good to me ;)
[Modified by RUXperienced, 11:41 PM 4/4/2003]
Old Apr 5, 2003 | 01:06 AM
FASGLAS's Avatar
FASGLAS
CI 4-5-6-7-8-9-10-11 Vet
St. Jude Donor '06-'07-'08-'09
Yep, sounds like a new FLASHER is needed. :yesnod:
Old Apr 5, 2003 | 10:41 AM
Randy 71's Avatar
Randy 71
Looks like a very nice day here to replace the flasher. Thanks to all for the advice.
Randy
To Turn Signal Question
