Matching Numbers on 1981 important???
There is a crowd that will pay more for a numbers matching origional car, so keep everything so you can put it back in case someone cares.
There is also another crowd who could care less about the next owner, so they make the car as they like it. If they have to sell it, they've got bigger problems.
There are people who just are looking for performance, so origional isn't getting it done.
best suggestion if it worries you so much is buy the rebuilt engine and stick the original in a deep, dark corner of your garage. that way you don't sink a bunch of money into rebuilding a mediocre engine and then continue to worry about resale if you blow it up a couple years down the line.
i don't think the '81 will ever be a particularly valuable year. gonna end up like the '75-'79 and '84s, just kind of the red-headed step children of the snobby nose crowd.
Comes down to personal prefrence. I don't think they are pulling a premium with original engine anyway. I know my 1980 won't be worth much of anything in the future (compaired to other c3s) so I'm not worried about keeping it stock.
Or is your car somehow exempt? (5000 mi./yr. or other)
Chuck the crossfire. They're limited to a maximum of about 330 hp, and simply do not flow well. If you want the "look", get yourself a vintage cross-ram manifold and put twin carbs on it. They make wonderful power, and you could probably reuse your stock air filter box and cowl induction system. Pop the hood and at first glance, it wouldn't look much different, except for the lack of the "spagetti factory" under the hood.
If you can't find a cross ram (I'd look on e-bay for starters, and check out the swap meet scene), then a straight carburetor on a modern dual plane would work fantastic. But so would a tuned port. No kidding. With minor modifications, a TPI provides INCREDIBLE torque through the midrange, right smack where all your street driving is. You'll get up to about 5000 rpm, so match it with a super torquey cam and go kill C5's all day long!!!!!!!!!!!!!!!!!
Also chuck the iron manifolds. They do not make power at all. The big problem is that the manifold is always pressurized, so when an exhaust valve opens, inevitably some of the exhaust gas gets pushed back into the cylinder. They do not scavenge well at all. I'd suggest a tri-Y header to maximize torque. There's a company making them again, it's in Summit's catalogue. They don't have one for a C3, but I'll almost guarantee that if you get one for a 67-69 Camaro/Firebird, it'll fit the Corvette with minor mods if any. The F-body has its crossmember under the engine, so the headers are made to clear that. The Vette's crossmember is in FRONT of the engine, so that's not an issue.
When you get heads, I suggest 1.94/1.60 valves if you're building a 355 (overbored 350). If you stroke to a 383, then get the 2.02/1.60 valves. Avoid the temptation to get mega-flowing heads with huge valves, because unless you're spinning 7 grand plus, you simply don't need them.
If you can afford a hydraulic roller cam, I'd get that. They make power like a solid flat tappet cam without the constant need to keep adjusting valves. If not, there are several hot hydraulic flat tappet cams out there, and if you're keeping your rpm's in the streetable torque range (below 6500 rpm) you'll make great power and you'll save gobs of money. Isky makes a VERY torquey cam, but because it's symmetric grind, it likes a good exhaust system. I'm talking DUAL exhaust. Don't worry, it's the same basic car as the early C3's, so it can convert to dual exhaust very easily. I'd go undercar 2.5" exhaust (no bigger because of that torque issue), with a crossover near the collectors and twin Flowmasters in back. You'll quickly fall in love with the howling sound of the Flowmasters!
And if anybody cares, or if you ever sell, you'll still have the numbers matching motor and can always bolt the "Misfire Injection" back on for selling purposes. If that ever happens, the new owner will appreciate the higher compression, better torque cam, and dual exhaust system. You'd lose 100 hp but you'll still make a lot of torque, even with the stock TBI system.
And definitely don't waste your money on forged this and forged that. Cast iron will handle all the torque you want in a street engine. Remember, you're not building a top fuel dragster. This has to be satisfying between traffic lights, and on the street, torque is definitely king!
Anyone who disagrees should drive my IROC just once.
:D
[Modified by Intimidator454, 10:43 PM 4/5/2003]
