Help for a squeaking front end
Old Apr 6, 2003 | 04:15 PM
ez1's Avatar
ez1
Default Help for a squeaking front end
Hi,
Anybody know what's making the front end on my 69 sound like a donkey? It's most noticible when I go over a speed bump. It goes HEEE on the way up and HAWWW on the way down. If I press and rock the front from either side It just screeches away. I had the ball joints greased and silicone sprayed the sway bar ends. Still screechin' :banghead: Any ideas?
Old Apr 6, 2003 | 04:46 PM
The Money Pit's Avatar
The Money Pit
Default Re: Help for a squeaking front end (ez1)
If you're using polygraphite sway bar mount bushings,try wrapping the bar where it contacts the bushings with teflon tape.(The white plumbers tape.)
This drove me nuts too,and worse yet I have no radio to drown out the HEE-HAW squeeks!
Old Apr 7, 2003 | 09:46 PM
isosceles's Avatar
isosceles
I had 2 cars that did that. The latter one being my Vette, and I am sure it was the control arm bushings. I had a whole poly front end kit done at Van Steel and the noise went away, so, I can't say 100% for sure it came from the control arm bushings because so many parts were replaced. :smash:
Old Apr 18, 2003 | 07:40 PM
ez1's Avatar
ez1
Default Re: Help for a squeaking front end (isosceles)
Hi All,
Thanks for all the tips and tricks. I've tried them all. I've been away or I'd have tried them sooner. I WD40'd pretty much the entire front end. I silicone sprayed it as well. I wrapped the sway bar bushings with teflon tape. :banghead:
I took her to Corvettes Unlimited. "It's the sway bar" he said. I told him what I'd done. He said they use a teflon spray. It made the squeaking somewhat quieter but it's still there. She goes back for a wheel alignment next week and they are going to take another look. I'll let you know how it works out.
Old Apr 18, 2003 | 08:57 PM
gravismaximus's Avatar
gravismaximus
sounds more like the control arm bushimgs to me, sway bar links clink and thud when loose, :chevy
Old Apr 18, 2003 | 09:08 PM
ez1's Avatar
ez1
Default Re: Help for a squeaking front end (gravismaximus)
I think so too. It makes the noise when the car goes up and down not around turns. Looks like I'm back under the car tomorrow :rolleyes:
Old Apr 23, 2003 | 10:58 PM
ez1's Avatar
ez1
She's back from Corvettes Unlimited any no more squeaks. Some white grease in the spring pockets and she's quiet as a mouse. I went back and forth over the speed bumps in the parking lot this morning and nary a sound. They also did a wheel alignment and she rides like a new car. So now I'm going to get new tires to replace the unevenly worn ones I'm riding on now (225/70/R15s). Any suggestions? I like big tires with white letters.
To Help for a squeaking front end
