What temperature does your SB Automatic run at in warm climate,AC running and in traffic? My car will climb to 230 if I sit in traffic with AC on,On the road it stays around 190 to 200,Is this normal?
Ok, good, so I am not the only one who's car gets hotter on the highway. These are the goofiest cars I've ever seen when it comes to cooling:crazy: . I thought the increased airflow would cool then down... every other car I ever had did.
An OD tranny will knock 20 degrees off your highway operating temps! The engine is working a LOT less harder because it will only turn 2/3 the rpms it was previously!!! :yesnod:
My '78 has a 190 degree thermostat so it stays between 190 and 220 on a hot day in Chicago. Beware though.....if you stop or are in heavy stop n' go traffic the temp will rise quickly. On one of our club outings we stopped for one of our cars having problems and I left my air running on a 95+ day. I came back to my car 5 minutes later and it was up to about 250! The other club members laughed and said I should no better than ot leave the air running on a standing still Corvette. Even the C5s will heat up to the danger zone if the air is left on will standing still. With two littel grills and a radiator tipped on an angle, there isn't much air blowing in. :mad :mad :mad
QUOTE
"Ok, good, so I am not the only one who's car gets hotter on the highway. These are the goofiest cars I've ever seen when it comes to cooling . I thought the increased airflow would cool then down... every other car I ever had did.
When you get over 45 the clutch fan free wheels and you start losing the air draw even at 60mph. The air dam or chin lip is absolutely needed for highways. A basic cooling problem of C3's is there is no place for the hot air to go, not enough draw. This is why the alum radiator and puller fans works so well on these beasts. A friend that races these things cuts louvers in the underside panels that cover the heater core and the charcol cannister which he says acts as a vent to draw the hot air out of the compartment. Have not tried it, but why not.
