Exhaust Flames
Old Apr 8, 2003 | 09:47 PM
82ttopvette's Avatar
82ttopvette
Default Exhaust Flames
I was tooling the Idea of installing a flame kit on my 82 that now has a carb on it. has any one done it and dou you need to run any extra fuel to the exhaust system. by the way I have gotten rid of all the emissions S*%$ thank for your help :cheers:
Old Apr 8, 2003 | 09:53 PM
trw's Avatar
trw
Default Re: Exhaust Flames (82ttopvette)
Do a search for this. There was a post last week with names of venders.
Terry
Old Apr 8, 2003 | 09:56 PM
battsup's Avatar
battsup
That would be really cool, all you need is a coil, a relay, a switch a 2 spark plugs. You need to install the spark plugs about 2 to 4 inches from the tip an dconnect them to the coil. then you need to connect your switch with the relay so that when you press the switch it will disconnect the coil for the engine, thus sending raw fuel down your pipes and then the the coil for the plugs in the back will allow you to shoot flames. Amazing what you can learn from watching TNN.
Old Apr 8, 2003 | 10:49 PM
ZD75blue's Avatar
ZD75blue
Default Re: Exhaust Flames (battsup)
On a steel car I might, but ours has resin and fiber mixed together for a body... might make a toasty critter outa myself with a flame a few inches off the bumper :eek:
To Exhaust Flames
