Uni-points vs. separate condenser
Old Apr 9, 2003 | 12:42 PM
mayberg's Avatar
mayberg
Default Uni-points vs. separate condenser
Gentlemen,
I'm working on a tune-up on the 74, and the points and condenser I got at Pep Boys is a so-called "Uni-points" where the condenser is integrated to the points assembly.
What I pulled out of the distributor is a separate condenser from the breaker points.
So I suppose that the black wire that went from the old condenser to the old points assembly is no longer needed with the Uni-points.
But there's also a black wire connecting the vacuum advance diaphram to a screw on the old condenser, and the new uni-points assembly does not have this screw. Is this simply a ground wire? On the new uni-points condenser, I connected this wire to the mounting screw - hopefully in a fashion where it's out of the way of the rotating part of the distributor.
What are your thoughts? Is that appropriate? Or am I mixing up parts inappropriately? Right now it's not starting.
Thanks, GM
Old Apr 9, 2003 | 01:24 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: Uni-points vs. separate condenser (mayberg)
I never buy parts from Pepboys. They straight up suck. Never have anything I need in stock and the people who work there are worthless. When I was running points before the ZZ4 I would to go to NAPA. They have good quality parts and the people that know cars working there.
