more brake work
Old Apr 9, 2003 | 10:17 PM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default more brake work
I'm back to doing my brakes. This time I'm going to hone both front calipers. Has anybody else had alot of success with this?
Old Apr 10, 2003 | 01:16 AM
PatG's Avatar
PatG
Default Re: more brake work (jonny4523)
Yes you can hone them. I would not bother unless you have SS sleeved calipers. Also I found that the stock pistons with lip seals will rock in the bore and cause uneven wear in no time. Might want to consider a zero tolerance o-ring upgrade while you are at it.
Old Apr 10, 2003 | 10:09 PM
jonny4523's Avatar
jonny4523
Default Re: more brake work (PatG)
where would i find the zero tolerance rings at?
To more brake work
