Casting Number Help
Old Apr 9, 2003 | 11:15 PM
jbegler's Avatar
jbegler
Default Casting Number Help
Does anyone have a Chevy casting number book that would be willing to look up a few numbers for me. These are all numbers off of a TPI setup. I bought these off of ebay and am thinking they are not off what he said they were. I just need to know what models these were used on. He told me they were all from a 87 Iroc Thanks for any help you can offer
Intake 14087069
ECM 1227165
Throttle Body 17075917
Intake Plenum 14081006
Fuel Rail 17085052
Injectors 523530
Thanks Again for any help you can offer me
[Modified by jbegler, 10:16 PM 4/9/2003]
Old Apr 10, 2003 | 07:12 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Casting Number Help (jbegler)
fuel rail shows its from a 85-87 305 tpi and the injector shows its a 305,but not to worry,i have the same setup from a 87 trans am 305,everything is interchangeable except the injectors and prom,switch to 350 injectors and a 350 prom (chip) and youll be fine.Actually some guys just use a adjustable fuel pressure regulator and bump up the pressure to 45 or so and then you can use the 305 injectors and prom,but your not getting all the performance out of it though.
[Modified by patsnitrovette, 7:15 AM 4/10/2003]
