Please help me find a cam
Ok, it is a 79 L-48 with THM-350 and 3:55 rear end(i think), Vortec heads, Edlebrock Perfomer Vortec manifold, dual exhaust, stock exhaust manifolds(plan on changing later). I am rebuilding the engine so I want to replace the cam to match everything that I have put in. The heads are the weak spring versions that are said to be good for .450in of lift(Scogin Dickey says I might be able to get away with a cam of .460 I think). I saw springs good for .490in in a Jegs catalogue so I'd replace them if I have too. I want a lot of low end torque. So what's everyone's recomendations?
For some torque I say something along the lines of the Comp Cam 262 or 268 cam. I ran the 268 in my 327 and really liked it. It had a great sounding idle, and had a good bottom end decent midrange.
:cheers:
:cheers:
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
http://www.compcams.com/information/...62H-10_001.asp
This is the cam I put in my car. It has the biggest torque numbers of any of the XE cams. http://www.compcams.com/information/...ts/DynoSheets/
This is the link for the rest of the XE dyno sheets. Give them a look.
[Modified by Eddie 70, 5:55 PM 4/10/2003]
I am thinking of a Comp Cams XE250H-10. Comp Cams dynoed it and it reached 412ft lbs. torque, so it doesn't seem that bad. Also anyone know how the GM Hi-Perf would be? When it comes to cams I'm kinda lost.
When I looked into cams I went to http://www.compcams.com/information/...on/default.asp and they sent me an email with the recommendation that a Magnum 270H would be perfect.
I went ahead and did another thorough analysis between a 268H, XE262H, and a Magnum 270H. Here's the spreadsheet: http://67.116.80.82/Vette/Files/Cam Comparison.xls
Basically, the 268H has the same grind for it's intake and exhaust lobes, the 270H is the same way. The XE262H however has an exhaust lobe grind that is very close to the 270H lobes. In my opinion anyone getting an XE262H is just wasting their effort at upgrading their valve train to support the exhaust lift while allowing the lower intake lift to choke their intake. A Magnum 270H has a very similar grind for BOTH intake and exhaust as does the exhaust lobe on the XE262H.
Cam grinds are a compromise. If not so, there wouldn't be any need for the thousands of choices out there. One guy has low gears and a stick or a high stall converter auto, another has tall gears and an auto. One guy cruises around town, another wants the lowest et's and at any cost to drivability. Personally, I'm very happy with a larger cam in my 327 than is being discussed here (XE-274) but it suits me and my car.
I agree that the 270H is a nice cam but I don't agree that an XE-262 would be a "wasted effort". I don't see how using any cam that has significantly more intake duration and lift than stock would "choke their intake".
Anyway...we all know that even a 256H would be much better than what was put in the L48's! :thumbs:
With the stock vortec heads and 1.5 lifters, you are limited to the following cams with less than .470 lift (that's pushing it):
GMPP (used in 350HO with Vortec heads): 212/222@.050; .435/.460 lift
Comp 265 Dual Energy, 211/221@.050, .442/.465 lift;
Comp XE262, 218/224@.050, .462/.469 lift;
Crane PowerMax H-266-2, 210/216@.050, .440/.454 lift;
Isky and Edlebrock cams are all low lift for the duration, you have to add 1.6 self aligning rocker$$$.
From what I read, the springs are not the problem, it's the retainer to seal clearance that limits total lift.
Joe
[Modified by joe73vette, 10:21 PM 4/14/2003]
Joe
