Speedometer wrong?
Old Apr 16, 2003 | 01:19 AM
djlangford's Avatar
djlangford
Default Speedometer wrong?
Howdy!
Finally got within visible distance of my wife today, and determined that at highway speeds, my speedo is ~10mph slow!! :chevy
It is a '74 auto, 454. The tires are 225/70R15's front and back, stock rims. I can't find what the stock tire sizes are in today's measurements. But, is there a way to fix this, or am I stuck with wrong mileage, and a ~10mph reading? Or, is buying new tires the only option?
I really don't want to buy new tires for it, I just spent a bunch of $$ on the motor rebuild, MSD ignition, etc, and want some more $$ for interior work, and don't have that many brownie points left with the wife! :eek:
Thanks,
David
Old Apr 16, 2003 | 01:43 AM
groovyjay's Avatar
groovyjay
Default Re: Speedometer wrong? (djlangford)
You can calibrate your tranny with new gears. Use this link to calculate you tire diameter:
http://www.smokemup.com/auto_math/tire_diameter.php
Old Apr 16, 2003 | 06:35 AM
Larry B.'s Avatar
Larry B.
225/70/15's are almost identical in diameter to the original. 27.4".. The above post is correct, you can get different gears for the speedo drive. That's at the transmissin end of the cable and is very easy to change. You do need to know how many teeth yours has so you can get one to replace it.
[Modified by silvervetteman, 6:36 AM 4/16/2003]
Old Apr 16, 2003 | 10:06 AM
djlangford's Avatar
djlangford
Default Re: Speedometer wrong? (silvervetteman)
Ok, so now I know that I have 27.4" tires, and a 35 tooth speedo gear, what do I do to calculate what I need?
Thanks,
David
Old Apr 16, 2003 | 10:43 AM
Schmucker's Avatar
Schmucker
Just call a transmission place and tell them what transmission you have, your tire diameter, and your rear gear and they can tell you want gear you need.
Old Apr 16, 2003 | 11:35 AM
isosceles's Avatar
isosceles
yup, speedo gear is cheap and easy to replace. Get new seal and/or O-ring if your's takes one.
Old Apr 16, 2003 | 01:46 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Re: Speedometer wrong? (Schmucker)
Each gear tooth is approx 3MPH. So you need to use 3teeth as the guide. To make the speedo go FASTER lose three teeth and Obviously if you want it to go slower, add three. :lurk:
To Speedometer wrong?
