How many HP..
Old Apr 16, 2003 | 04:47 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default How many HP..
could I gain by switching from a mechanical fuel pump to a electrical fuel pump.. I have heared that it's in the range of around 5 HP to 10 HP...
Is this true??
:cheers:
Olivier
Old Apr 16, 2003 | 05:10 PM
TedH's Avatar
TedH
Default Re: How many HP.. (GrandSportC3)
My feeling is that if your mech fuel pump is 'tired' there is room for improvement with even a fresh mech pump. If it is a fresh, performance mech fuel pump already, less improvement.
A word of caution: Be careful with electronic fuel pumps. My brother torched his garage when he mistakenly broke a fuel line off at the electric fuel pump, the fuel spilled all over his garage floor and was ignited by a kerosene space heater (ie. with no way to stem the fuel flow, gravity took over). Pretty nasty. He was soaked in gasoline and was very lucky to not become a human roman candle; just some rash from the raw gasoline.
Old Apr 16, 2003 | 05:19 PM
GrandSportC3
Default Re: How many HP.. (TedH)
Well - I have a pretty new (1 year old) Carter 120 GPH fuel pump.. I was thinking in getting the Holley 140 GPH pump... I would like to see some dyno test results that compare mech. with electrical pumps...
Old Apr 16, 2003 | 07:30 PM
jimtreber's Avatar
jimtreber
Are you watching your fuel pressure throught the traps? That's where I got a clue. Less than 2 pounds wasn't cutting it for me.
Old Apr 16, 2003 | 07:49 PM
QuickVet's Avatar
QuickVet
Default Re: How many HP.. (jimtreber)
That why I got mine :yesnod: Dont think you would see much difference on the dyno tho. not unless you are not getting enough fuel. but with your MPH, I doubt that
Old Apr 16, 2003 | 09:57 PM
GrandSportC3
Default Re: How many HP.. (QuickVet)
I don't have a fuel pressure gauge that is visible for the driver.. The only thing that I know is that - the higher the RPM are - the leaner I run...
To How many HP..
