Radio interference, this is odd
Old Apr 19, 2003 | 08:37 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Radio interference, this is odd
I had a lot of ignition type interference to my radio, so I bought and installed an MSD supressor that wires to the 6A unit box. When I started the 72 the radio sound was nice and clear. I figured I had the problem solved. But when I put the air cleaner back on, the interference was back. :eek: Take the air cleaner off, and the radio sounds ok.
Now what? :confused: Carbon fiber air cleaner? There has to be a reasonable answer.
[Modified by biltogo, 7:49 PM 4/19/2003]
Old Apr 19, 2003 | 09:46 PM
74BBcherryred's Avatar
74BBcherryred
Default Re: Radio interference, this is odd (biltogo)
I have seen this on some other cars ,they run a braded wire from the wing nut on the breather to a ground on the engine block. You may have seen something like this on cars that have a flexable piece of metal that hangs down from there hoods that make contact with the air cleaner when the hood is closed. You cannot use that type on a vette because they are fiberglass Dave :seeya
Old Apr 21, 2003 | 12:26 AM
AlwaysWave's Avatar
AlwaysWave
Default Re: Radio interference, this is odd (74BBcherryred)
:cool: I grounded the air cleaner lids with some jumper wire to test out. It worked :cheers: :cheers: At least 90% of the noise went away. Now I'll make up something permanent. Thanks :cheers: :cheers:
Old Apr 21, 2003 | 12:38 AM
gdh's Avatar
gdh
I'm having the same rfi problem, will try grounding the air cleaner and then buy a MSD noise suppression unit as well. Have the same plugs and 6AL unit. When the engine is not running the radio and cd are fine but soon as I start the engine, I can't even listen to the stereo.
[Modified by gdh, 12:40 AM 4/21/2003]
Old Apr 21, 2003 | 03:12 AM
standup's Avatar
standup
Was Yoko Ono playing on the radio? She can always sound a bit buzzy.....
Old Apr 21, 2003 | 03:25 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Radio interference, this is odd (gdh)
It "sounds" like the metal dish of the air cleaner is a perfect antenna for picking up MSD signals and directing them to the radio.
Very odd. :crazy:
Old Apr 21, 2003 | 08:11 AM
RMVette's Avatar
RMVette
Default Re: Radio interference, this is odd (standup)
:lol:
To Radio interference, this is odd
