HELP! my door is stuck
Old Apr 20, 2003 | 06:08 PM
Randexter's Avatar
Randexter
Default HELP! my door is stuck
ok so this morning i was changing the oil so i go and unlock the passanger side door and no problems so i am all finished and lock the door but i had forgoten my phone in the car so i go to unlock the door but the dammed thing doesnt budge, then i went around and tried to unlock it from the inside same thing what do I do. :confused:
Old Apr 20, 2003 | 07:03 PM
Enkil's Avatar
Enkil
Default Re: HELP! my door is stuck (Randexter)
Dubya-Dee-40! :D
(wd40, that is)
I had a similar problem, the locking mechanisms, well... locked. Couldn't turn the key, couldn't get it unlocked from the inside... Try spraying a bunch of wd40 into the door handle, maybe it'll drip down to the lock. I got lucky and managed (after many days of trying) to force the lock open. I looked pretty stupid climbing over the passenger's seat in the meantime. Once I did manage to get it unlocked I took the door panel off and soaked it with wd40. Hasn't given me a problem since.
Old Apr 20, 2003 | 07:16 PM
Randexter's Avatar
Randexter
Default Re: HELP! my door is stuck (Enkil)
wow that sucks i would hate to get in from the passangers side door i think i would be way embarased oh well i guess im not to bad off just not giving any rides any time soon.
thanks :D
Old Apr 20, 2003 | 07:37 PM
jerryp58's Avatar
jerryp58
You could also roll down the window and try spraying the mechanism with WD-40 (or the lubricant of your choice) from above.
Old Apr 20, 2003 | 07:45 PM
Alwyn678's Avatar
Alwyn678
Default Re: HELP! my door is stuck (jerryp58)
I had the same thing happpen my lock mechanism was worn out. I managed to get the door panel off with the door shut...........NOT AN EASY JOB. Then took out the lock mechanism and replaced it with a new one. If you have to do this I hope your hands are small.............not fun :nonod:
Old Apr 20, 2003 | 07:53 PM
Spook's Avatar
Spook
Default Re: HELP! my door is stuck (Alwyn678)
You can always go with the dukes of hazard stylus... jump in baby!
Spook :flag
To HELP! my door is stuck
