Any recommendations for tires?
Old Apr 23, 2003 | 11:01 PM
ez1's Avatar
ez1
Default Any recommendations for tires?
Hi,
I'm looking to replace my 225/70/R15s with ? I have a 69 convertable and like big tires with white letters (out :D ) Any suggestions?
Old Apr 24, 2003 | 06:48 AM
Larry B.'s Avatar
Larry B.
Default Re: Any recommendations for tires? (ez1)
Be carefull before ordering. 255/60's hit the mufflers AND e-brake bracket when I tried them on my stock 69. I had to stick with 225/70's... Others have been able to use 255's but some can't.
Old Apr 24, 2003 | 06:54 AM
groovyjay's Avatar
groovyjay
go with 245 rears and 235 fronts. :yesnod:
Old Apr 24, 2003 | 08:29 AM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: Any recommendations for tires? (groovyjay)
I have 245/60/15 all the way around. Work great. ck out my web site.
Old Apr 24, 2003 | 09:29 AM
1LE's Avatar
1LE
BFG Radial TA's 255-60-15's al the way around, no problems with rubbing.
Old Apr 24, 2003 | 09:49 AM
tshort's Avatar
tshort
CI 7-8 Veteran
What about WHICH tire? I've had BFG Radial T/A's but want to get something with a higher speed rating and possibly better traction. Not concerned with wet traction. Any recommendations?
What kind of speed rating do BFG Drag Radials and Nitto drag radials have?
I currently have 15" TT's.
[Modified by tshort, 8:50 AM 4/24/2003]
Old Apr 24, 2003 | 10:19 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Re: Any recommendations for tires? (1LE)
:iagree:
Old Apr 24, 2003 | 10:23 AM
TTop Tony's Avatar
TTop Tony
Default Re: Any recommendations for tires? (tshort)
If you look on tirerack Pirelli has a scorpion 255/60 that has a vr rating. About the only 15 inch tire I have seen with that high a rating.
Old Apr 24, 2003 | 10:42 AM
Rockn-Roll's Avatar
Rockn-Roll
Hmm, I just posted some info on this...lets see...
http://forums.corvetteforum.com/zerothread?id=543195
Here's an excerpt:
Now...if you want PERFORMANCE, and willing to sacrafice an inch or two on your ride height, then take a look at the smaller tires...for example:
Pirelli P600 : 235/60-15 rated: 180 A A real sticky tire full 10/32" tread depth
Dunlop SP Sport 8000 : 245/50-15 rated: 200 A A another sticky tire, but this one has 9.1" of tread width with 9.6" section width...nearly a flat sidewall nice and stiff...a little more tread than even the BFG 255/60-15. Nice looking tire.
If you want to be a trailer queen then carry some tires with you...how about these:
Hoosier R3S03 rated: 40 C A (a couple of runs down dry track with only 4/32" of tread). You will not spin these suckers!
There's a few others, but I think you get my point. Also look at the prices. A good performance tire will cost you about $150 each, which is why most of us go for the BFG RADIAL T/A or the FIRESTONE which we can get two for the price of one.
If you are interested in the excel file, you can find it here:
http://67.116.80.81/Vette/Files/TireRackTires2001.xls
http://67.116.80.81/Vette/Files/TireRackTires2002.xls
http://67.116.80.81/Vette/Files/TireRackTires2003.xls
I just updated the 2003 file at the beginning of this month. You can take a look at how the industry has been eliminating performance tires in the sizes we need by comparing these files. But, as I pointed out...some tires like the Dunlop SP Sport 8000 235/50-15 will fit like a snake.
To Any recommendations for tires?
