Hard Start after Warm-Up
Old Apr 24, 2003 | 12:14 AM
Corvette Lady's Avatar
Corvette Lady
Navigator
Default Hard Start after Warm-Up
I own a 1980 Corvette, runs great ( now that the vacuum leak is fixed) but after the car has been driven when I shut it off it won't restart. It's not the battery or volts as it cranks fast it just won't catch and fire up. Feels like not gas is getting to engine. If I sit and wait after several attempts to restart, the car will suddenly come to life and starts right up. Any thoughts? Carburator or ignition or what?
Once it starts it runs like a dream.
Thanks to the gentlemen that helped me with the vacuum leak which was causing a shaky idle. That's fixed - Thank you.
Old Apr 24, 2003 | 12:25 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Hard Start after Warm-Up (Corvette Lady)
sounds like the starter got heat soaked :skep:
Old Apr 24, 2003 | 12:33 AM
Black Snowman's Avatar
Black Snowman
I have the exact same issue with my '78 TA. I put a new battery and starter on and the only reason that it helped is it brought my cranking RPMs up enough that I can "power through" with about 1/4 throttle until it kicks off.
It seems like what I've heard called "vapor lock" but I'm not sure excatly what the problem is or how to cure it but I'm pretty sure it's carb related. Any gurus out there want to enlighten us? :confused:
Old Apr 24, 2003 | 12:48 AM
Corvette Lady
Navigator
Default Re: Hard Start after Warm-Up (Corzvette69)
Got your email, thanks. When a starter is overheated I thought you just heard a clicking sound from the engine, am I wrong? because my engine is winding up just won't catch, no clicking sound. But you may be on to something which is why after I wait a few minutes it finally starts - starter would be cooling down. Thanks!
Old Apr 24, 2003 | 01:43 AM
Steve Grodin's Avatar
Steve Grodin
If you have heat soak the starter won't turn the engine over. :chevy
Old Apr 24, 2003 | 06:58 AM
devveldogg's Avatar
devveldogg
Definitely sounds like heat soak. I bought a heat shield that clips on the solenoid at my local “zone”. Seems to help. :seeya
Old Apr 24, 2003 | 07:20 AM
IRON WILL's Avatar
IRON WILL
Default Re: Hard Start after Warm-Up (devveldogg)
Doesn't sound like a starter issue to me. Might be a weak fuel pump. Where it can get the fuel in better when cold cause the choke is kicked on. Where after it is warm the choke is off and less Vacuum is created making it harder to take in fuel. Especially if the pump is weak. Also could be the ignition modual. These have been know to cause problems when the car gets hot. I would do some simple checks next time you have a problem. Pull a plug out and check for spark, hold it against something to ground it. Don't hold it with your hand, use a screw driver or something that has a plasitc handle. Then get somebody to crank the engine over while you watch the plug to see if it is getting spark. If it is then your problem is elsewhere. To check to see if your getting fuel, take the air cleaner off and look down the carb while somebody cranks it over. Be Carefull, do not look straight down the carb, kinda look from the side. If it were to backfire through the carb you might be painting on new eyebrows. Thats where I would start. Good luck.
Old Apr 24, 2003 | 07:24 AM
Jvette73's Avatar
Jvette73
Since it cranks fast but wont start I would rule out a starter problem. Vapor lock is caused by fuel in the lines boiling from high underhood temps. An engine expierencing vapor lock will usually start at first but then die out shorly after. From what you describe, it sounds like an intermitant problem of no spark to the plugs. You probably have an HEI distributor which uses an ignition module mounted inside the distributor to controll spark. I would suspect the module is causing the problem. They can fail intermitantly like that. Next time it happens, open the hood and tap on the base of distributor with a tire iron. It may fire right up then, which could support the faulty module idea. The HEI on my truck would do this and I could get it to start right away most of the time by tapping the dist base. Somehow it would shock the module into function again. I recently replaced that dist and have had no problems with it since.
Old Apr 24, 2003 | 07:26 AM
groovyjay's Avatar
groovyjay
If you don't even get the clicking sound, it's the solenoid, that is enjioying too much heat! I had the same problem. You can try to solve it with some Termo Tec stuff. I just swapped for Hamburger mini starter, it was the final cure! :cheers:
Old Apr 24, 2003 | 07:56 AM
norvalwilhelm's Avatar
norvalwilhelm
Had this same problem. Cold the car started right up but pull in for gas, shut it off and you prayed it would start. After a few attempts it fired right up but it was embarrassing cranking it and wondering if I was going to need it pushed away from the pumps.
It turned out to be an leaking foat bowl. The fuel would leak out the bottom of the carb when the motor was shut of flooding the motor. After a few attempts at starting the motor would clear itself of raw fuel and fire right up.
How I discovered this is when I got home I removed the sight plugs in the fuel bowls, in my case 4 of them with twin carbs and watched the floats. Sure enough one level dropped.
I left it over night and the one dropping was clearly going down continually. I replaced the metering plate and all my starting problems went away.
If it' s a holley the metering plate can develope and internal leak. It most likely in not the gasket. I tried replacing the gasket after remachiing the gasket surface to make the plate flat but it never worked.
Good luck with your problem but is sure sounds like a leak to me.
Old Apr 24, 2003 | 08:42 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Re: Hard Start after Warm-Up (norvalwilhelm)
:iagree: I had a very similar problem. Sent my carb (q-jet0 to Lars for surgury. He found that I had a defect causing the carb to leak into the manifold and causing a very difficult start after warm up. Pretty easy to verify - warm the car up and remove the carb. If it's leaking, you'll see fuel in the intake. Good luck to ya. :cheers: :smash:
Old Apr 24, 2003 | 09:52 AM
NHvette's Avatar
NHvette
Default Re: Hard Start after Warm-Up (Avette4me)
I support two of the above theories:
Norvals idea of the carb leaking into the intake ... and ...
John's idea of an intermittent ignition module.
I have seen these symptoms in both these cases before.
Good luck. The ignition module is the easiest to fix or try - IMO.
:seeya
Old Apr 24, 2003 | 10:35 AM
Rockn-Roll's Avatar
Rockn-Roll
Definitely a carb problem. Chances are the engine is running too rich, possibly due to the choke not opening all the way or not soon enough. A quick test would be to drive it until it gets warmed up, then shut it down, take the air cleaner off and inspect the choke plate to make sure it's in the wide open position. If not, then adjust it so that it's open all the way...it should then start fine.
During spring and fall the air temperature is moderate so the choke may not be adjusted well enough to open all the way during spring, or close enough during the fall. When I was a fleet mechanic I found that some vehicles always need some adjusting to their choke during the change in seasons.
Hope this helps
Old Apr 24, 2003 | 10:44 AM
bbeck's Avatar
bbeck
Just to get things straight, does it try to fire? but can't stay running? I didn't see where you stated one or the other. If it fires, but doesn't stay running, I'd go with a starter- selenoid's bad. Had that problem on my car, now starts everytime, no problem.
Old Apr 24, 2003 | 10:45 AM
GR8T WYT's Avatar
GR8T WYT
Default Re: Hard Start after Warm-Up (Rockn-Roll)
To Rockn-roll :iagree: :cheers:
Old Apr 24, 2003 | 11:29 AM
Stefan69's Avatar
Stefan69
Default Re: Hard Start after Warm-Up (Steve Grodin)
:iagree:
It could be vapor lock. vapor lock means that the fuel in the lines gets very hot and builds a fuel vapor. This gets pumped into the carb. And then the car won't drive. However VL usually means that the car starts on the gas in the fuel-bowl and then stops.
So you more likely don't have a strong enough spark. Or you have the carb dumping fuel down the manifold. Does it smell "rich" after a successfull hot-start? If so, you probably get too much gas.
Good luck. This kind of troubleshooting can be a pain :(
Prost:cheers:
Stefan
Old Apr 24, 2003 | 11:40 AM
john's '81 mouse's Avatar
john's '81 mouse
Agree with Rockn-Roll and others suggesting a fuel rich problem to me.
My '81 acts just like Norval said, and after running a short while, like going to gas station and shutting it off, sometimes it won't re-start, and I take the air cleaner lid off, and stick a screw driver in choke butterfly to hold it open, and the engine then starts right away! I guess I need to adjust the electric choke or linkage, but I don't see any adjustment screws on my electric choke, just rivets.
Old Apr 24, 2003 | 12:13 PM
Black Snowman
This is my problem with my T/A. I don't even have to look. I can SMELL the gas now that I cut open my shaker. Damn, and I already rebuilt the thing. It's probably warped. Since I can start it now I think I'll save putting money into it and have that go tward the 'Vette fund :cheers:
Old Apr 24, 2003 | 10:31 PM
Corvette Lady
Navigator
THANKS TO ALL OF YOU WHO REPLIED TO MY POST. THE PROBLEM IS SOLVED ..
IT TURNED OUT TP BE THE DISTRUBUTOR. THERE WAS NO SPARK AT ALL. HAD ROTOR, IGNTION COIL AND MODULE REPLACED. CAR STARTS FINE NOW.
THANKS AGAIN FOR EVERYONES SUGGESTIONS.
To Hard Start after Warm-Up
