Carpet install problems
Old Apr 26, 2003 | 08:41 PM
killain's Avatar
killain
Oldtimer
Default Carpet install problems
What is the best way to soften carpet so it can be glued in place? :bb
Old Apr 26, 2003 | 08:59 PM
Bobchad's Avatar
Bobchad
Default Re: Carpet install problems (killain)
Lay it out and let it get warm.
I didn't glue mine. The angles combined with the seats, etc. made it stay in place.
Old Apr 26, 2003 | 10:15 PM
gmcclurg's Avatar
gmcclurg
Default Re: Carpet install problems (Bobchad)
If you are using a molded set, you shouldn't have to glue it. It will lay flat
Old Apr 26, 2003 | 10:20 PM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Carpet install problems (gmcclurg)
Are you talking about the smaller pieces like the kick panels or speaker covers? Or the whole floor area? If it's the small pieces, try a blow drier on them or, depending where you live, 15 minutes in the hot sun should do it. I don't usually glue the floor area down.
Post a pic when it's done.
Good luck, Greg
Old Apr 27, 2003 | 06:02 AM
killain's Avatar
killain
Oldtimer
Default Re: Carpet install problems (Greg)
Thanks Greg, I live in Pennsylvania and Sunday is going to be a warm day. I'll try leaving them out in the sun. It's the kick panals I'm doing right now and the two pieces are about six years old and left over from the front carpet set I installed then. I'm now carpeting the rear area and that carpet is larger but the base is still firm. I suppose this is a summer only job? Thank you for your help. :)
Old Apr 28, 2003 | 12:41 PM
UKPaul's Avatar
UKPaul
I'm doing my front carpets at the moment & found that the floor pan is covered in black bitumen (or someting similar). Is this normal????
:cheers:
Old Apr 28, 2003 | 12:52 PM
Bobchad's Avatar
Bobchad
Default Re: Carpet install problems (UKPaul)
My 77's floor pans were coated in this stuff, appeared to be paint to me that flaked up in spots. Because I have metal floor pans, I scraped up all the loose pieces and then some and covered with POR-15.
Old Apr 28, 2003 | 12:55 PM
apple76's Avatar
apple76
K- once you get the carpet removed, I would get some 'Rust Converter' or some rustoleum paint and do the floor boards...
To Carpet install problems
