Car dies when..
Old Apr 27, 2003 | 10:02 PM
battsup's Avatar
battsup
Default Car dies when..
it is kicked off the choke, otherwise it sounds great at the high idle(1600rpm). Any takers?
Old Apr 27, 2003 | 10:05 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Car dies when.. (battsup)
sounds like you dont have the fast idle cam and idle screw adjusted right
Old Apr 27, 2003 | 10:10 PM
Jvette73's Avatar
Jvette73
big vacuum leak? Carb base gasket bad? EGR valve stuck open? hmmm
Old Apr 27, 2003 | 10:16 PM
Jvette73's Avatar
Jvette73
Make sure a chunk of foam from the pro flo cleaner didnt drop down in there cause something to clog up. Those things are notorious for that.
To Car dies when..
