AC question
Old Apr 28, 2003 | 12:38 AM
JohnsRed79's Avatar
JohnsRed79
6th Gear
Default AC question
I bought my car last year from someone who only owned it for a month( he buys them and cleans them then resales them), I want to get the AC working (there was no belt on the compressor) What steps should I take to see if the parts on the car now work or need replacing. Since I cant ask the original owner to see what mechanical is wrong with the AC or if it was just disconnected to save power, I didnt know where to begin and sure dont want to pay a garage to look at it. Thanks
Old Apr 28, 2003 | 07:24 AM
virtue4u's Avatar
virtue4u
Default Re: AC question (JohnsRed79)
If it was converted to R134a, then you might just buy a new belt, charge it up and see if it works. If it is still a R12 system, then you better make sure it will hold a charge because R12 is too expensive to waste through a leak. Chances are the seller knew it needed major repair and didn't want you to find out. Consequently, he took the belt off before the sale.
Old Apr 28, 2003 | 08:59 AM
page62's Avatar
page62
When I was buying, 90% of the C3s I looked at had the A/C belt removed. And 90% of the people tried to :bs me by saying it just needed freon. I'm sorry to say this is very seldom the case.
At the very least, you're looking at replacing the compressor -- the seals are likely shot by now. Probably the hoses and the accumulator/drier (or whatever it's called), too. I know because I bought a C3 with non-working A/C. It cost me nearly a thousand bucks to get it working again!
Start saving your $$$, and start shopping around for a place that won't skin you alive!
Old Apr 28, 2003 | 02:28 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
If the compressor hasn't been run for an extended period of time chances are the seals are shot. Most owners manuals suggest running the a/c for a few minutes, even in the winter, if possible to keep everything lubricated.
Old Apr 28, 2003 | 02:47 PM
john's '81 mouse's Avatar
john's '81 mouse
Agree you'll likely need a new or rebuilt compressor...........many don't like rebuilts, citing high failure rate.........and new accumulator. Must get system vacumed down to 28 inches for 1/2 hour to an hour, then you can charge system yourself if you also convert to R-134a, which will require purchase of a conversion kit. If you do work yourself, you can be all done for less than $500, maybe around $400.
To AC question
