Power windows problems
Old Apr 29, 2003 | 03:57 AM
Engo's Avatar
Engo
Cruising
Default Power windows problems
I have a problem with the power windows on my 74 Coupe. The windows won´t go to the full top position. They stop around 2 inches from the top position but the engine is stil spinning. Seems like the drivegear disengages at that position. I´m guessing the linkage or gears are worn but wanted to know before I start tearing everything out. Is this a common problem?
Old Apr 29, 2003 | 04:25 AM
FinnShark's Avatar
FinnShark
Default Re: Power windows problems (Engo)
Sorry can't help you with your powerwindow guestion. Sounds pretty much about worn out drive gear though...
But, WELCOME to the forum from your eastern neighborhood country!
And then next thing, we are crazy about pics, so could you be so kind to post few pics about your car! It's always good to have more people from Europe to join in! :cheers:
Old Apr 29, 2003 | 08:54 PM
Larry B.'s Avatar
Larry B.
This is caused by worn teeth on the regulator. Eckler's sell a repair kit that just gives you a section of new teeth so you can fix yours rather than replacing the whole assembly.
Old Apr 30, 2003 | 03:38 AM
Engo's Avatar
Engo
Cruising
Default Re: Power windows problems (bluevetteman)
Ok, thanks. I´ll check into that Ecklers repair kit.
Old Apr 30, 2003 | 10:11 AM
Ganey's Avatar
Ganey
Agree that it is probably the "regulator gear". Suggest replacing the gear w/ aftermarket instead of the SS section. Explained why previously in another topic on this.
To Power windows problems
