Turn Signals
Old Apr 29, 2003 | 09:58 AM
t69man's Avatar
t69man
Default Turn Signals
Hi,
Just got the car back from the body shop and noticed that the right turn signals no longer work. The left side is fine. After I cleaned out the contacts on the front, I got lights but no flashing. I changed the flasher relay with the same results. When I was checking the blubs, I did drop and break the front blub. I had another one that looked the same, but I'm wondering if these are special blubs and having the wrong type in there could cause the lights to come on, but not flash.
Old Apr 29, 2003 | 01:38 PM
427basketcase's Avatar
427basketcase
Default Re: Turn Signals (t69man)
The bulbs are nothing special, dual filiment. Either a 1157 or 1034, a bad bulb or ground can cause what you are describing. I would change bulbs first then clean the ground wire connections. (Corvettes love a good ground!)
Old Apr 29, 2003 | 03:21 PM
Surfer69's Avatar
Surfer69
Check wiring under back end, connections can get bad due to wires flying around.
To Turn Signals
