Freaky Braking...
Old Apr 29, 2003 | 09:25 PM
Omega1's Avatar
Omega1
Default Freaky Braking...
Just recently after the first time out after winter storage, my 77 started doing the wierdest thing...when i hit the brakes my car shoots right...it never did this before i put it away. It was on the verge of needing pads & possibly rotors before i put it away and i haven't driven it much since it came out...any ideas anyone?
Old Apr 29, 2003 | 09:29 PM
Yellow79's Avatar
Yellow79
Default Re: Freaky Braking... (Omega1)
any insight on this would be great as mine has just recently started doing the same thing....
Old Apr 29, 2003 | 09:36 PM
TheVin's Avatar
TheVin
Sounds like your driver's side caliper is hangin up on you, if you hit the brakes and shoot to the right, your passenger side is working with little or no help from the other. I'd look at that caliper see if it's moving or not.
Good luck
Old Apr 29, 2003 | 10:56 PM
Rockn-Roll's Avatar
Rockn-Roll
Give it a good bleed to get all the old fluid out. Here's a helpfull link:
http://67.116.80.82/Vette/BrakeHelp/BrakeHelp.html
Old Apr 30, 2003 | 12:34 PM
midwest-vette's Avatar
midwest-vette
Check for leaking caliper. Mine jerked left and the left caliper was bad.
Old Apr 30, 2003 | 02:15 PM
Adam Wartell's Avatar
Adam Wartell
Default Re: Freaky Braking... (midwest-vette)
I had a similar problem a few months ago!
It eventually got to the point were the pedal went to the floor before the car stopped!
I rebuilt all 4 calipers... putting in new O-Ring pistons. Now it stops like a champ! I got the pistons from ZTI... http://www.zerotoleranceind.com/
Keep us posted on what you do!
Old Apr 30, 2003 | 03:47 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Left caliper is bad. :(
Easy to fix. :yesnod:
Old May 1, 2003 | 03:52 AM
Omega1's Avatar
Omega1
I planned on all new calipers, rotors, pads...the whole nine yards as a tuneup for the big block goin in...which will finally happen this summer...hopefully that solves it...thanks everyone!
Old May 4, 2003 | 09:31 AM
ram82fire's Avatar
ram82fire
TTT
Old May 4, 2003 | 11:26 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Freaky Braking... (adamw1979)
What did you do? Did you install the stainless sleeves yourself and then ordered the pistons from Zero Tolerance? Can you give a good description of the process? I have some old brakes lying around and may upgrade them to 0 tolerance before I sell them to a buddy of mine. I'd like to know what's involved before ordering (I'm overseas)
Marck
Old May 4, 2003 | 03:49 PM
Adam Wartell
Default Re: Freaky Braking... (Twin_Turbo)
Marck
Actually, I didn't do them myself, a friend of mine did them for me. No sleeves are involved. He had to hone out the piston hole because from the factory, they have a tiny lip at the bottom. Once they are honed, you just slip the new o-ring pistons in place. It seems really easy, if you have the honing tool. If you want to email him directly, let me know, and I'll shoot ya his email address.
Old May 4, 2003 | 05:09 PM
Twin_Turbo's Avatar
Twin_Turbo
but were yours stainless steel linered? Honing is not am problem.
oh, please I'd like the guy's addy. I need to decide what to do w/ my old calipers :)
[Modified by Twin_Turbo, 4:13 PM 5/4/2003]
Old May 5, 2003 | 11:15 AM
Adam Wartell
No. They did not have a lining.
Old May 5, 2003 | 03:14 PM
Twin_Turbo's Avatar
Twin_Turbo
what's his addy?
To Freaky Braking...
