WTF is that noise!
Old Apr 30, 2003 | 04:54 PM
TJRed76's Avatar
TJRed76
Default WTF is that noise!
Went out to start the Vette last night. It turned over twice and then made a horrible slamming/grinding sound. After I sat stunned for a moment, I tried it again with the same result.
I don't know what to do. Could it be the starter, the flywheel, what else?
I am paniced. What do I check first? :confused:
Old Apr 30, 2003 | 05:06 PM
Fevre's Avatar
Fevre
Default Re: WTF is that noise! (TJRed76)
I know that sound all to well, it's the sound of money running out your pocket.
Can you tell where the sound is coming from? Might try unhooking the coil and have someone give it a quick crank while you listen to where the sound is possibly coming from then proceed from there.
Hope it's nothing serious. :(
Old Apr 30, 2003 | 07:53 PM
Boofers's Avatar
Boofers
Have you made any recent changes to the engine like a new cam, change the timing or remove the starter?
Old Apr 30, 2003 | 07:59 PM
Desertvette's Avatar
Desertvette
Had a similar experience last month and it was the starter mount bolts loose. Made a heck of a noise but did'nt hurt anything and only took a minute to fix. Lotsa luck
Bob
Old Apr 30, 2003 | 08:03 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: WTF is that noise! (Desertvette)
Mine does that once and a while... I just turn the key all the way off, then try again and it'll start fine. But I hate that grinding noise :cuss
Old Apr 30, 2003 | 08:40 PM
hauk's Avatar
hauk
Default Re: WTF is that noise! (Metal_Wulf)
Mine did that yesterday,I found that it broke the nose on the starter :smash:
Old May 1, 2003 | 02:14 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: WTF is that noise! (Fevre)
I know that sound all to well, it's the sound of money running out your pocket. :(
OOPH !!! that hurts... :lolg: :iagree:
Old May 1, 2003 | 01:28 PM
TJRed76's Avatar
TJRed76
Default Re: WTF is that noise! (Desertdawg)
A friend of mine brought his booster pack over, and the car started fine. When we got it to his garage, we tried it again and the noise was back. Put the booster pack on, no noise.
He thinks that it is a problem with the starter when the juice is low. He'll check it out today when we're putting the dual exhaust in.
Old May 1, 2003 | 02:49 PM
rollavette71's Avatar
rollavette71
Sounds to me like your starter solenoid is headed south. The solenoid is allowing the starter gear to start turning before it has engaged the flywheel.
Hank
To WTF is that noise!
