Brodix heads on a '72 -- headers?
Old May 1, 2003 | 12:41 PM
cheeksspi's Avatar
cheeksspi
Navigator
Default Brodix heads on a '72 -- headers?
Sorry, I had to revise my question that I had earlier. I need to put new headers on my '72 small block, because I put Brodix heads on my car, and my current headers don't fit because of the angled plugs. My problem is not only that the plugs run into the headers, but apparently Brodix heads have "raised ports" which make them a little different then other angled-plug heads. The header manufacturers are very hesitant to tell me that their headers will fit my car because of the Brodix head. I guess my question is: does anybody have Brodix heads on their C3 small block, and if so, what headers worked? Maybe the manufacturers are a little too cautious, and everything will be fine, but before I buy the headers I want to make sure the combination worked for someone else, because it sounds like that would be the only gaurantee I'll get.
Thanks,
Adam
Old May 1, 2003 | 12:45 PM
Pete79L82's Avatar
Pete79L82
Default Re: Brodix heads on a '72 -- headers? (cheeksspi)
What model Brodix head do you have?
Old May 1, 2003 | 12:49 PM
JIM's Avatar
JIM
Default Re: Brodix heads on a '72 -- headers? (Pete79L82)
I have brodix and am running the stock exhaust manifolds. No problem with the plugs.
[Modified by JIM, 9:54 AM 5/1/2003]
Old May 1, 2003 | 01:39 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Brodix heads on a '72 -- headers? (JIM)
I have the Track 1's that will be going in my car on the new engine :)
To Brodix heads on a '72 -- headers?
