Dual Exhaust ???
Old May 3, 2003 | 12:45 PM
mvftw's Avatar
mvftw
Default Dual Exhaust ???
I'm planning on converting from the 2-Y's & cat, to true duals with no cats. 2 shops recommend 2 1/4" not 2 1/2" + 'H' pipe (I have a 4 spd). Because it's a low compression motor (motor will be kept stock). I see other guys went with 2 1/2". What do you think...
Old May 3, 2003 | 12:52 PM
Ganey's Avatar
Ganey
Default Re: Dual Exhaust ??? (mvftw)
Yes, do it. See Why Exhaust is problem for HP on 75-81
what many refer to as my Exhaust topic. http://www.corvettefaq.com/c3/ganeyexhaust.htm
Some ex. pipe size guidelines. You want flow not turbulance.
DUALS
2" .... 200 BHP
2.25" 320 BHP
2.5 .. 400 BHP
3.0 .. 600 BHP
Old May 3, 2003 | 01:59 PM
Disco_Mike's Avatar
Disco_Mike
Default Re: Dual Exhaust ??? (Ganey)
Gainey,
Thanks for the numbers. My father and I put Headers and dual exhausts on back in 1980. 23 years and the custom bend work is showing its age. Indesisive on what to do with exhaust. but think now ill keep headers and dual exhaust. the ceramic coated ones sound cool (pun intended)
Old May 3, 2003 | 02:28 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Ganey, I found a page on dynomax's website that has slightly different info. They say 2.25 for 250HP and 2.5 for 300-400 HP.
Scroll down the page: http://www.dynomax.com/techsupport.stm
Either way, I think 2.25 will be plenty of exhaust for a stock 78 engine. Also, the H-pipe size should be at least 70% of the size of other pipes. No harm in making the H-pipe the same size as exhaust pipes.
Old May 3, 2003 | 06:58 PM
mvftw's Avatar
mvftw
Default Re: Dual Exhaust ??? (Captain Morgan)
Thanks for the info...to be continued.
Old May 3, 2003 | 07:11 PM
stpman's Avatar
stpman
Any plans at looking at the difference between "H" pipe and an "X" pipe?
Steve :steering:
Old May 3, 2003 | 07:55 PM
Ganey's Avatar
Ganey
Captain Morgan
An excellent link which includes C.I. The guidelines I posted were from Racing Head Service. Comparison below.
Racing Head Service..... Dynomax
DUALS
2" .... 200 BHP...............100-200
2.25" 320 BHP................250
2.5 .. 400 BHP................300-400
You are ahead of this topic & have already answered the next issue which is whether he intends to remain basically stock in which the 2.25 should be fine w/ rec. high flow mufflers. If he intends to go for more HP, then 2.5.
Suggest Increase Power.
:cool:
Old May 3, 2003 | 08:06 PM
corvettemaster's Avatar
corvettemaster
i've been around here for a while and have never read that thread. it's very interesting. ganey, i have stock exhaust manifolds, with 2" dual exhaust all the way back to monza style tips. i have also swapped cams to a crane cam with 260/272 a. duration. how much of a power increase do you think that gave my stock L-81?
Old May 4, 2003 | 11:12 AM
Ganey's Avatar
Ganey
Default Re: Dual Exhaust ??? (corvettemaster)
The link to that thread has been posted many times by many. Did that topic for you guys. The new guys need to see it. Would prefer not to post it myself.
You are approaching 300.
Old May 4, 2003 | 10:00 PM
ndirishr1's Avatar
ndirishr1
I'm running 2.5's on my '68.
To Dual Exhaust ???
