Speedo cable with tremec TKO?
Old May 4, 2003 | 05:25 PM
zwede's Avatar
zwede
Default Speedo cable with tremec TKO?
So what did you guys with Tremec TKO's do for your speedo cable? The way it is angled it seems there's no way to keep it from contacting the exhaust pipe (unless you have sidepipes, of course). I wrapped aluminum heat insulation around it but that didn't work. The speedo died today. I figure the cable got too hot, bind, and stripped the plastic gear in the tranny.
I have a 90 dgr adapter on order and hope that will let me get the cable away from the exhaust.
Old May 4, 2003 | 07:27 PM
fauxrs's Avatar
fauxrs
Default Re: Speedo cable with tremec TKO? (zwede)
Where did you order your 90 deg adapter - I'm having the same issue as you
Old May 4, 2003 | 07:58 PM
zwede's Avatar
zwede
Default Re: Speedo cable with tremec TKO? (fauxrs)
Ecklers is the only place I could find them.
Post mortem on the speedo is the cable is jammed and snapped the adapter. Great.
Old May 4, 2003 | 08:26 PM
norvalwilhelm's Avatar
norvalwilhelm
I used the ford version of the Tremec TKO and the speedometer cable came out well in front of the crossmember.
This is a poor shot but without the exhaust pipes installed.
Old May 4, 2003 | 09:40 PM
zwede's Avatar
zwede
Default Re: Speedo cable with tremec TKO? (norvalwilhelm)
Yeah, that's what mine looks also. But with exhaust pipes running through the crossmember the pipe touches the cable. Can't bend it enough to clear.
Old May 5, 2003 | 10:18 AM
fauxrs's Avatar
fauxrs
is that designed for the tach drive cable - or the speedo cable - or is there a difference?
Old May 5, 2003 | 10:22 AM
zwede's Avatar
zwede
They're designed for the tach cable but luckily for us the Vettes use the same for both.
Old May 5, 2003 | 01:00 PM
71roadster's Avatar
71roadster
I wish I could offer something. So far mine is working, tho I did have to bend the cable a little tighter to get it off the exhaust. Probably don't have enough miles on it to no if it will last. How much was the 90 degree adapter (just in case)?
Chris
Old May 5, 2003 | 01:16 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Speedo cable with tremec TKO? (71roadster)
Going through the same with the 700R4 and VSS sensor.
Old May 5, 2003 | 02:44 PM
zwede's Avatar
zwede
Chris
$50.
Old May 5, 2003 | 04:24 PM
fauxrs's Avatar
fauxrs
:iagree:
Yep - ordered mine this morning
Old May 5, 2003 | 04:46 PM
zwede's Avatar
zwede
Just wanted to post that Swarr (Swarr automotive where I bought the tranny) was nice enough to send me a new speedo adapter shaft even though I told him how it broke and it really wasn't the fault of the adapter.
To Speedo cable with tremec TKO?
