Zero Tolerance brake piston users
Old May 5, 2003 | 04:05 PM
redvetracr's Avatar
redvetracr
Default Zero Tolerance brake piston users
Just curious if anyone (besides me) had to grind the bore of a stainless steel sleeved caliper just below the sleeve so the ZTI pistons would bottom out in the caliper?? My calipers are so bad I had to grind all 16 bores and one bore was not even round enough to accept the piston, that caliper half went back for an exchange. ...redvetracr
Old May 5, 2003 | 05:32 PM
ram82fire's Avatar
ram82fire
Default Re: Zero Tolerance brake piston users (redvetracr)
I have installed a few sets of the o-ring kits. It seems some of the people sleeving these units do not take the time to locate the bore center . I have had some sets that were centered and some that were not .
Geo
Old May 5, 2003 | 07:30 PM
flynhi's Avatar
flynhi
I did the same with my SS lined calipers. A little Dremel and all is well. Been using them for about 5 years and no problems with rear wheel pumping.
Old May 5, 2003 | 08:31 PM
PatG's Avatar
PatG
Yep. that is what I did. As mentioned, some bores were worse than others.
To Zero Tolerance brake piston users
