1.8 Mutsi Eclipse/Talon engine
Old May 6, 2003 | 05:54 PM
mrvette's Avatar
mrvette
Default 1.8 Mutsi Eclipse/Talon engine
anybody know anything about them...?? single cam supposedly a bad bearing....won't run...any ideas???
GENE
Old May 6, 2003 | 05:56 PM
Corey_68's Avatar
Corey_68
Default Re: 1.8 Mutsi Eclipse/Talon engine (mrvette)
They have a bad rep of "crank walk". Do a search online, you should find what years are worse than others, it's not rare by any means.
Found a link to it ---> http://www.machv.com/wal19tur.html
:cheers:
[Modified by Corey 68, 4:57 PM 5/6/2003]
Old May 6, 2003 | 05:59 PM
terryrudy's Avatar
terryrudy
If its a 2.0 then its the turbo. Sounds like it might be the non-turbo motor. No crankwalk problems. Believe its the same motor used in the Neon.
-terry
Old May 6, 2003 | 06:06 PM
mrvette's Avatar
mrvette
Default Re: 1.8 Mutsi Eclipse/Talon engine (terryrudy)
It is a 1.8 non turbo, automatic car, SOHC plain jane engine....
thing is somehow some kid/idiot/whoever might have ran it out of oil and so the stick is clean, and the dealer says engine is no good,...knows nothing more...beleive ME, this guy does NOT know cars....from India/Paki etc....
BUT the saving grace is, the car is CLEAN, and I don tmean just car lot clean...it's NOT bad at all....panels line up, paint matches, no dents/dings....interior nice enough....for a '93 afterall....
but the thing is that damn ENGINE....need information...
GENE
Old May 6, 2003 | 06:13 PM
terryrudy's Avatar
terryrudy
good luck, may want to check http://www.dsmtrader.com for deals on used parts for cheap. Looking now, a lot of folks parting out 1.8s there.
-terry
Old May 6, 2003 | 11:01 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Re: 1.8 Mutsi Eclipse/Talon engine (Corey 68)
:iagree:
Crank walk is a big problem with the Mitsu 4 banger motors. A good friend of mine had it happen on his GSX eclipes. It was pretty funny watching the pulleys and all move when he pushed in the clutch.
Old May 6, 2003 | 11:07 PM
Schmucker's Avatar
Schmucker
Crankwalk is only a problem on second generation DSMs with manual transmissions. If I can recall correctly the DSM in question is a first generation therefore it does not have a problem with crankwalk.
Old May 6, 2003 | 11:10 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: 1.8 Mutsi Eclipse/Talon engine (Sigforty)
I had a turbo once that the balance shaft spun out. Shaked violently at about 3000 rpms. If it want turn over and there is no oil. I'd say no go. Those cars burn up valve stem seals very easy. Just look at all the black smoke on the bumpers.
To 1.8 Mutsi Eclipse/Talon engine
