Side gapped spark plugs (mod)
Old May 7, 2003 | 07:25 PM
adam's Avatar
adam
Default Side gapped spark plugs (mod)
Anyone ever hear about this?
They grind back the the finger to expose the electrode...
This is from the 'world's largest engine link in another thread...
http://performanceunlimited.com/illu...parkplugs.html
Old May 7, 2003 | 08:04 PM
ram82fire's Avatar
ram82fire
Default Re: Side gapped spark plugs (adam)
It is hardly a well kept secret ,,,, I started doing it in the late fifties . BTW there were a lot of folks doing it before I did .
Geo :thumbs:
Old May 8, 2003 | 02:19 AM
The Dude's Avatar
The Dude
What do you think those little teeny cutoff wheels for your Dremel are perfect for? Yes, this is an old, old trick.
Old May 8, 2003 | 03:49 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Side gapped spark plugs (The Dude)
Yeah! What he said.. :iagree:
Old May 8, 2003 | 04:31 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Side gapped spark plugs (Desertdawg)
May be an old trick (look at the dinosaurs who replied :) :D ) But the young-uns know about it too, guilty here
Marck
[Modified by Twin_Turbo, 5:05 AM 5/8/2003]
Old May 8, 2003 | 09:00 AM
DeenHylton's Avatar
DeenHylton
My Autolite racing plugs come side-gapped right out of the box.
Deen
Old May 8, 2003 | 09:31 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Side gapped spark plugs (DeenHylton)
Never heard of this before. I may have to give it a try. Why not cant hurt too much can it.
Old May 8, 2003 | 10:06 AM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Side gapped spark plugs (Eddie 70)
I didn't know about it. What exactly do you do?
Old May 8, 2003 | 10:25 AM
MYBLU71's Avatar
MYBLU71
Default Re: Side gapped spark plugs (tshort)
Been there... done that... :yesnod:
I use Bosch Plus (Dual Electrode) or Bosch +4 (four electrode) now. :crazy: :seeya
Old May 8, 2003 | 11:25 AM
adam's Avatar
adam
Default Re: Side gapped spark plugs (MYBLU71)
Well I presume that this shortens the life of the plug - not that plugs are expensive,
but at 1 hr to replace them, its a pain...
Anyone measure any gains doing this - the page mentioned better performance, etc.
Is this strictly a race technique or street too?
Old May 8, 2003 | 11:50 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
adam, i've heard the same thing. i've wondered about running this on the street too. i've thought about giving it a try but figured it's not worth the hastle when i'm already running .080" gap. who's running this on the street and how long? any adverse affects?
Old May 8, 2003 | 12:02 PM
Alwyn678's Avatar
Alwyn678
Default Re: Side gapped spark plugs (clutchdust)
Never heard of it........................... :confused: An real gains
Old May 8, 2003 | 01:30 PM
corvettemaster's Avatar
corvettemaster
i've never heard of this either. the page above says:
"Side Gapping" has been a well kept secert for many years in the racing circles. this will substantially increase horsepower, torque and fuel economy with no sacrafice to your wallet.
sounds good to me :yesnod: but is it ok to do it to a street car :confused:
Old May 8, 2003 | 01:33 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Side gapped spark plugs (corvettemaster)
Tried it no noticible gains??????
Old May 8, 2003 | 01:42 PM
Missileman's Avatar
Missileman
Did this to my drag camaro in the mid eightys. Lost a tenth in the quarter mile but it caused the electrode to wear quicker and I was replacing plugs too often (headers were a pain).
Old May 8, 2003 | 01:49 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Side gapped spark plugs (Cali,77,L-82)
You will most likely only see a gain if you have a very high compression and huge domes where the actual flame front shrouding by the electrode is substancial. In a somewhat normal engine side gapping is a nice thing to do and allows you to accurately set the gap. Rremember the gap is the shortest distance between the 2 poles, like this:
some spark plugs can be gapped like this:
.. grr.. pic doesn't appear AGAIN. URL: http://www.crossfire.homeip.net/twinnie/gap2.jpg
[Modified by Twin_Turbo, 1:20 PM 5/8/2003]
Old May 8, 2003 | 02:00 PM
WashingtonRacer's Avatar
WashingtonRacer
Well yes they do give a bit more power but do shorten the life of them considerably. mainly make a set and use them for racing only. Many people actually go a step further and cut the electrode off at the bend, and then just push the side in closer. This way yo have a complete open kernal. As for those 4 electrod crap spark plugs. Why waste the money? you are only blocking more of the kernal from the mixture. And it's not going to spark to all 4 points. Even if you managed to have it spark to all 4, That would not be a good thing. All that means is the the current is 4 times weaker when jumping the gap. In reality the spark is only going to jump the closest gap and it will always be that one. If it mis fires, It's not going to go to the next closest. cause after all. if it's not going to make it past the closest gap, why would it make it past the second closest. All in all, A good set of NGK's should do the trick.
To Side gapped spark plugs (mod)
Old May 8, 2003 | 02:09 PM
Pete79L82's Avatar
Pete79L82
I have done test with this on the dyno on both mid-compression motors (10-1 to 12-1) and on high compression motors (13-1 to 16-1) and could not find any measurable horsepower differences. This seems to be an old urban ledgend that won't go away.
Old May 8, 2003 | 02:18 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Side gapped spark plugs (WashingtonRacer)
Yes, that was in my 2nd pic.. that does not appear :mad I hate this resize thing.
Old May 8, 2003 | 03:23 PM
adam's Avatar
adam
There is some value in 4 electrodes - the spark will jump to the closest gap, TRUE.
But a sharper edge is closer than a rounded discharged away edge.
So, with 4 electrodes, you have 4 times the contact area of a single side gapped
electrode. But as to the effectiveness of the spark, others have said no.
