Yet another brake question
Old May 8, 2003 | 08:49 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default Yet another brake question
OK, here's my dilemma. Changed all calipers. Changed front brake lines. Bled the dayum things 3 times (gettin’ a power bleeder to try the 4th). Brakes want to go to the floor. I get air out every time, they'll run 20 miles or so, and back to the floor.
I cannot find a leak and it's beyond me how I can get more air in without pushing fluid out. The air can't be coming in with more than a couple of pounds of pressure and when you push the brakes you are applying several hundred pounds. Have I not gotten all the air out or how can I have a leak (caliper, line, etc.) without seeing fluid somewhere.
:banghead: :banghead: :banghead:
Old May 8, 2003 | 08:54 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Yet another brake question (Avette4me)
Did you have your rotors trued when you put the new calipers on? They may be pumping air in while you are driving.
Old May 8, 2003 | 09:08 AM
Avette4me's Avatar
Avette4me
Default Re: Yet another brake question (Eddie 70)
I had them turned. Can they suck air without pumping fluid out?
Old May 8, 2003 | 12:29 PM
mayberg's Avatar
mayberg
Even having them turned doesn't necessarily mean that they are true, since there may be runout on the hub or spindle. You might consider getting 'hold of a dial indicator and measuring your runout.
Your rotors may be true to themselves and still wobble installed on the car. That would get air into the system.
Old May 9, 2003 | 04:59 PM
WESCH's Avatar
WESCH
Hi
The brake caliper O-ring kit ( from VBP ) for about 120 $ will eliminate the air pumping problem.
Check out previous posts on this.
Best safety conversion I did so far on my 68 big block.
I also had the aft discs turned and they where OK, but when installed , the drivers aft disc had runout, obviously coming from the spindle ?
I underlayed it with high speed alu tape until runout was minor.
The car brakes like never B4 and no more air sucking at all.
Good luck Gunther :seeya
Old May 9, 2003 | 05:03 PM
Avette4me's Avatar
Avette4me
Default Re: Yet another brake question (WESCH)
Thanks to all - I'll be working on her this weekend.
While I agree with ou, it is still beyond me how I can suck air without leaking fluid. Perhaps some things are not meant for me to understand, just fix!
Thanks again. :cheers:
Old May 9, 2003 | 05:14 PM
goofygrin's Avatar
goofygrin
Its not a sealed system... the spring pushes on the pad into the disk. As the disk turns, if the runout is out, one side of the pad will be pushed out (and this 1/2 of the pistons) and then the other side will be pushed out. This action turns the pistons/pads into an airpump, pushing air into the lines (and making the fluid level probably go up?).
That's my understanding at least.
Some people say to just get rid of the spring. Others say the oring is the solution (the oring makes the most sense to me).
Old May 9, 2003 | 05:20 PM
MYBLU71's Avatar
MYBLU71
Default Re: Yet another brake question (goofygrin)
What has been described as "pushing air into the system" is not really exactly that... what happens is when the rotor is not trued to the spindle, it has a wobble effect. After a few miles, it pushes the pads into the pistons similar to when you do this by hand before removing the pads. Ever notice that you have to pump the brakes a few times before they get firm again after changing pads? Same thing.
Good luck with your new ride... :cool:
Old May 9, 2003 | 05:29 PM
Avette4me's Avatar
Avette4me
Interesting. Thanks for the lesson, I'm always out to better understand. Funny, I had the entire suspension apart without much of a problem and am getting eaten alive by a simple hydraulic system.
Dayum :banghead: :D
Old May 10, 2003 | 01:35 AM
Rockn-Roll's Avatar
Rockn-Roll
Yes. Air molecules are much smaller than brake fluid molecules. You may have air getting in at the connections, or it does sometimes happen that new calipers leak air. This is why you need to use the brake pedal to pump fluid through. When you press down it will force air/fluid through the system and out the bleeder valve. When you release it then air will get into the system if there is a large enough hole for it even if it's not large enough for fluid to leak out. Thus, you can see which caliper the air is coming in at...check all the line connections...if you suspect a connection then loosen it and retighten it...if you have tried two calipers and both leak, then there may be a pin-hole leak in the line.
Here's my help URL:
http://67.116.80.82/Vette/BrakeHelp/BrakeHelp.html
Old May 10, 2003 | 07:44 AM
iniguy's Avatar
iniguy
I have just been through one hell of a fire drill with C-3 brakes. At this point I consider myself an expert. If you have no luck this weekend feel free to e-mail me and I will try to help you out. iniguy@direcway.com
Old May 12, 2003 | 02:21 PM
WESCH's Avatar
WESCH
It does, that's for sure. My brakes always succed air and absolutely no leak was ever found.
The O-ring convesrion fixed it.
I think it's just the setup of the lip seals that make it so easy to get air into the caliper, but no fluid out as the seal lips seal on pressure builup.
The O-rings do a positive sealing both ways.
Gunther
To Yet another brake question
