Replacement Battery
Old May 9, 2003 | 04:23 PM
C5USA01's Avatar
C5USA01
Default Replacement Battery
A friend of my wife has a 1982 Vette that is driven very little. The battery died and needs to be replaced. Any recommendations on a replacement battery, vendors, etc.?
Old May 9, 2003 | 04:26 PM
Fevre's Avatar
Fevre
Default Re: Replacement Battery (Joe Carlozo)
Can never go wrong with a DieHard. No special battery required for a vette, I actually use an undersized one to make it easier to remove when needed.
Old May 9, 2003 | 04:30 PM
77Dream's Avatar
77Dream
Just get any name brand from a local store, be sure to take in the old battery because there may be a core charge.
:cheers:
Old May 9, 2003 | 06:52 PM
vette_c5c6's Avatar
vette_c5c6
Dollar for Dollar the best Batt is the GM Delco, No leaks, last at least 5 to 7 years. That is my battery of choice.
Old May 9, 2003 | 06:57 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: Replacement Battery (vette_c5c6)
:withstupid:
although i also like the new gel batteries available now too... no acid
:yesnod:
[Modified by SIGNGUY, 6:58 PM 5/9/2003]
Old May 9, 2003 | 07:04 PM
77Dream's Avatar
77Dream
Here's a thought... get one with both the side and top terminals. Top ones being the post type and the side being the screw-in type. I have one and it makes it allot easier when you have to jump it or hook something up real quick.
:cheers:
Old May 9, 2003 | 07:21 PM
Fevre's Avatar
Fevre
Default Re: Replacement Battery (77Dream)
:cheers:
Great idea! :thumbs:
Old May 9, 2003 | 07:40 PM
Touringpro's Avatar
Touringpro
Optima Red Top
AGM, 3yr. full replacement/7yr. pro-rated, completely sealed, can't spill or leak, vibration proof, top & side terminals. $100 +- (Costco, Pep Boys, etc.)
[Modified by Touringpro, 4:44 PM 5/9/2003]
Old May 9, 2003 | 07:43 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Replacement Battery (Touringpro)
gel is the only way to go :thumbs:
Optima is a great choice, and i've also been hearing good things about the Delco Glasmat too.
Old May 9, 2003 | 08:53 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This is the new battery I installed in my 71. :D
Old May 9, 2003 | 09:16 PM
Rockn-Roll's Avatar
Rockn-Roll
If it tends to sit a long time, then I would recommend a deep cycle battery. It can drain all the way down to nil, but still be in good working order. It can also be quick charged with no problems. It's a tight fit in the compartment, but I got the biggest deep cycle to fit in mine.
Kragen/Checker/Schucks has an Exide Nautilus Megatorque group 24 battery that I think is the best, but they also have a smaller one that should work well.
Old May 9, 2003 | 11:54 PM
71coupe's Avatar
71coupe
Default Re: Replacement Battery (gq82)
Optima - same battery since X-mas of '98. No need to worry about venting this type of battery. All orig type batteries have outside vent tubing.
I had a wet-sytle battery gas up on me once (no vent tubes, of course). My eyes were watering all the way to the parts house :sad:
Old May 10, 2003 | 12:14 AM
OkeeGuy's Avatar
OkeeGuy
Optima Red Top
YUP! that tha one! :yesnod:
Old May 10, 2003 | 02:38 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Replacement Battery (SIGNGUY)
I have an Optima red top in my jeep for 9 years now, and it gets bounced and jiggled to death. I used to kill wet cells every 6 months.
Optima is the way to go :thumbs:
Old May 10, 2003 | 11:09 AM
aussiejohn's Avatar
aussiejohn
Default Re: Replacement Battery (Desertdawg)
Take the advice of TOURING PRO, SIGNGUY and Desertdawg (and me). Optima is the way to go
Regards from Down Under
aussiejohn
To Replacement Battery
